Community
cancel
Showing results for
Search instead for
Did you mean:
Jason_M_1
Framework choosing screen not showing on new apps
Jump to solution
When you create an app, choose a framework for it, then delete the app (both from the XDK project list, and from the disk), then create another app with the same name, you will not be able to see again the framework choosing screen and XDK will assume the same framework you had chosen before in the app with same name.
There is some place where app settings are stored but not cleared... where could I go look at meanwhile it is fixed?
Tags (2)
PaulF_IntelCorp
This is a known issue. I'm not sure where that information is being stored (remember the name of a project and the framework associated with that name). My suspicion is this info is stored in the global-settings.xdk file.
Make a copy of your global-settings.xdk file before making any changes. Search for the word "framework" inside that file and I think you'll find what you're looking for. I haven't tried this but I suspect all you need to do is remove the "framework": entry where you find it. Make sure you still have a valid JSON file after you make your changes (watch the commas).
PaulF_IntelCorp
Jason_M_1
Thanks Paul, I'll look into it.
