Software Archive
Read-only legacy content
17060 Discussions
Gesture Recognition
PowerMan_T_
Hi Guys,
Is there a difference in coding the dynamic gestures vs. static. I set EnableAllGesture(). The "swipe" "wave" gestures are not being recognized. All the other gestures work fine.
I didn't see anything specified in the reference manual
Colleen_C_Intel
Be sure to use the wave and swipes as defined in the SDK (see UX guide). In R1, Swipes are called from the Touchless Controller. Wave and swipe shouldn't be used at the same time (easily confused). Best to only enable the gestures you will use and not use enable all except for testing.
HexLord
I enabled the swipe gesture but it always detects two swipe gestures  at once.
Is there a way to slow it down?
Shaleen
Carles_V_
You can do it yourself using a timer.
Colleen_C_Intel
Is it detecting left and right together or two of the same direction?
The swipe is more a slow waving of the fingers (from pointing at the camera to pointing to the middle of the body area.
