Software Archive
Read-only legacy content
17060 Discussions
Help! How to get Intel Premier support ?
ne0
I am trying to download the Intel IPP crypto library. This seems to require a premier account which i am not able to get.
Please, if someone could give us a clue that would be helpful.
Thanks!
Intel_Software_Netw1
Entitlement to Intel Premier Support is granted per product, although you will typically use a single login to access all support areas you are approved for. Typically, you obtain access to a support area by registering your product. The Intel Software Development Products Registration Center is here: https://shale.intel.com/registrationcenter/register.asp
If you have questions or run into difficulties as you go, the Intel Software Development Products support team can be contacted directly at: developer.support@intel.com
I hope this helps.
Lexi S.
IntelSoftware NetworkSupport
http://www.intel.com/software
Contact us
Message Edited by intel.software.network.support on 12-07-2005 03:48 PM
