Software Archive
Read-only legacy content
17060 Discussions
Help me! Problem: Using 89C51 to control LCD
lepbinh
Hi!
I have a LCD two line, 20 character per line which name is TC2002A (made in China).
I using 89C51 microcontroler to control it.
And my program to load to 89C51 is writen follow:
; WRITE THE TEXT "HELLO WORLD" TO LCD PROGRAM
; I CONNECT THE PORT P2 OF 89C51 TO DATA BUS OF LCD
; WHERE P2.0, .. P2.7 AND DB0, .. DB7 CONNECT TOGETHER RESPECTIVELY
; AND THESE LINES CONTROL I CONNECT RS TO P3.0; RW TO P3.1; EN TO P3.2
RS BIT P3.0
RW BIT P3.1
EN BIT P3.2
DATA EQU P2
MESS: DB 'HELLO WORLD',0
ORG 0H
AJMP MAIN
SEND_STRING:
; TRANSMIT STRING WHICH POINTED TO BY DPTR.
; STRING MAY BE ANY OF LENGTH, BUT MUST BE MULL-TERMINATED.
SEND:
CLR A
MOVC A, @A+DPTR ; GET CHARACTER
JZ BREAK ; CHECK FOR TERMINATOR
ACALL WRITE_TEXT ; SEND CHARACTER TO LCD
INC DPTR ; POINT TO NEXT CHARACTER
AJMP SEND
BREAK
RET
WAIT_LCD:
SETB EN
CLR RS ; IT'S A COMMAND
SETB RW ; IT'S READ COMMAND
MOV DATA, #0FFH
MOV A,DATA ; READ THE RETURN VALUE
JB ACC.7,WAIT_LCD ; IF BIT 7 HIGH, LCD STILL BUSY
CLR EN ; FINISH THE COMMAND
CLR RW ; TURN OFF RW FOR FUTURE COMMAND
RET
INIT_LCD:
SETB EN
MOV DATA,#06H ; ENTRY MODE SET
CLR EN
LCALL WAIT_LCD
SETB EN
CLR RS
MOV DATA,#0EH ; TURN LCD ON AND THE CURSOR ON (DISPLAY ON/OFF CONTROL)
CLR EN
LCALL WAIT_LCD
SETB EN ; START LCD COMMAND
MOV DATA,#38H ; FUNCTION SET (8 BIT TWO LINE)
CLR EN
LCALL WAIT_LCD
CLR EN
LCALL WAIT_LCD
MOV DATA,#80H ; SET DISP RAM ADDR
SETB EN
LCALL WAIT_LCD
RET
CLEAR_LCD:
MOV DATA,#01H
CLR EN
LCALL WAIT_LCD
RET
ADD_DDRAM_SET:
MOV DATA,#80H
CLR EN
LCALL WAIT_LCD
RET
CURSOR_HOME:
SETB EN
MOV DATA,#02H
CLR EN
LCALL WAIT_LCD
RET
WRITE_TEXT:
SETB EN
SETB RS
MOV DATA,A
CLR EN
LCALL WAIT_LCD
RET
MAIN:
MOV SP,#5FH
CLR RW
LCALL INIT_LCD
LCALL CLEAR_LCD
LCALL ADD_DDRAM_SET
LCALL CURSOR_HOME
MOV DPTR, #MESS
ACALL SEND_STRING
AJMP $
END
; THE END OF PROGRAM
when i build and load the hex file into 89c51 and then turn of the power to run it. I see nothings in lcd, except the character which have ascii is 11111111B in the second line.
What wrongs?
Some once could help me.
Intel_Software_Netw1
While this questionis outside the scope of topicscovered by Intel Developer Services, Intel does offer technicalsupport for MCS 51 Microcontrollers at this URL:
We hope this is helpful.
Lexi S.
IntelSoftware NetworkSupport
http://www.intel.com/software
Contact us
Message Edited by intel.software.network.support on 12-07-2005 03:33 PM
