Software Archive
Read-only legacy content
17060 Discussions
Hiost License Transfer
Michael_V_2
I need to move two floating licenses of parallel_studio_xe_2016_update3 from an older machine to a new cluster.  I have the hostid's and server names of both.  Actually, I have the existing license file as well.
Michael_V_2
<Host> License Transfer.  Can't edit my own post.
Devorah_H_Intel
Hello  ,
This article explains how to change hostID and server information and obtain new license file:
https://software.intel.com/en-us/articles/change--serverhost-data-node-locked-or-floating-license
Please let me know if the above helps and/or if you need further help.
Michael_V_2
Here is the logfile output:
14:34:16 (lmgrd) FlexNet Licensing (v11.13.1.3 build 176483 x64_lsb) started on beluga0 (linux) (7/15/2016)
14:34:16 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights Reserved.
14:34:16 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
14:34:16 (lmgrd) License file(s): /opt/intel/licenses/server.lic
14:34:16 (lmgrd) lmgrd tcp-port 28518
14:34:16 (lmgrd) (@lmgrd-SLOG@) ===============================================
14:34:16 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
14:34:16 (lmgrd) (@lmgrd-SLOG@) Start-Date: Fri Jul 15 2016 14:34:16 EDT
14:34:16 (lmgrd) (@lmgrd-SLOG@) PID: 32556
14:34:16 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.3 build 176483 x64_lsb ( build 176483 (ipv6))
14:34:16 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
14:34:16 (lmgrd) (@lmgrd-SLOG@) Listening port: 28518
14:34:16 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
14:34:16 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
14:34:16 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c /opt/intel/licenses/server.lic -l /opt/licmgr/licenseserver//lmgrd.log
14:34:16 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  /opt/intel/licenses/server.lic
14:34:16 (lmgrd) Starting vendor daemons ...
14:34:16 (lmgrd) Started INTEL (internet tcp_port 56849 pid 32558)
14:34:16 (INTEL) Unable to initialize access to trusted storage: 2
14:34:16 (INTEL) FlexNet Licensing version v11.13.1.3 build 176483 x64_lsb
14:34:16 (INTEL) SLOG: Summary LOG statistics is enabled.
14:34:16 (INTEL) SLOG: FNPLS-INTERNAL-CKPT1
14:34:16 (INTEL) SLOG: VM Status: 0
14:34:16 (INTEL) SLOG: FNPLS-INTERNAL-CKPT2
14:34:16 (INTEL) Server started on beluga0 for:
14:34:16 (INTEL) IBDB034BC (consisting of:              AdvXEl
14:34:16 (INTEL) ArBBL          CCompL          Comp-CL
14:34:16 (INTEL) Comp-DCAF      Comp-FL         Comp-OpenMP
14:34:16 (INTEL) Comp-PointerChecker DAAL-L             DbgL
14:34:16 (INTEL) FCompL         IClsTktL        IClsValL
14:34:16 (INTEL) ITrAnlL                ITrAnlW         ITrColL
14:34:16 (INTEL) MKernL         MPassL          PerfAnl
14:34:16 (INTEL) PerfPrimL      StaticAnlL      ThreadAnlGui
14:34:16 (INTEL) ThreadBB)
14:34:16 (INTEL) Wrong hostid on SERVER line for license file:
14:34:16 (INTEL)        /opt/intel/licenses/server.lic
14:34:16 (INTEL) SERVER line says e60afae6, hostid is "80000208fe80 80000209fe80 14187770f13f 14187770f13b 14187770f13d 14187770f141"
14:34:16 (INTEL) Invalid hostid on SERVER line
Devorah_H_Intel
Did you verify that the hostID in the license file matches the system's? (as per article linked above). If you are unable to change it please send me the SN, new hostID/servername via " Send Author a Message" link.
Michael_V_2
This is the output of the hostname & hosted command on the license manager……..
       # hostname ; hostid
                beluga0
                e60afae6
This is the output of the ‘lmutil lmhostid’ command….
    # /opt/licmgr/licenseserver/lmutil lmhostid
                lmutil - Copyright (c) 1989-2015 Flexera Software LLC. All Rights Reserved.
                The FlexNet host ID of this machine is ""80000208fe80 80000209fe80 14187770f13f 14187770f13b 14187770f13d 14187770f141""
                Only use ONE from the list of hostids.
The ‘hostid’ output by the lmutil command appear to be matching a list of detected infiniband GUIDs instead of the system’s hostid.
What should be used as the hostid in the license file?
Devorah_H_Intel
Please use only one of these:
I am not familiar  with infiniband though.
