Community
cancel
Showing results for
Search instead for
Did you mean:
王_子_
How can I increase the FFT efficiency of MKL on MIC?
I want to use fftw3 library on MIC, but I can not find a appropriate method to accelerate the FFT .
I use these codes,but the speed slower than  the cpu code .
#pragma offload target(mic:1) in(in:length(nx*ny))\
			      out(out:length(nx*ny))
	fftwf_plan temp= fftwf_plan_dft_2d(nx,ny,in, out, FFTW_BACKWARD, FFTW_ESTIMATE);
	fftwf_execute(temp);
 So I want to ask two questions:
1.the implention of FFT can not use openmp,If I want to use ,what should I do ? Just use "#pragma omp parallel for" can not compile the code.
2.Can the method of fftw make full use of  the MIC computation resource? Do I need to try other methods of using FFT?
Thanks !
Evgueni_P_Intel
Hi 王 子,
You may want to consider using Intel MKL which provides a implementation of FFTW interfaces optimized for Intel MIC architecture -- https://software.intel.com/en-us/intel-mkl
Evgueni.
McCalpinJohn
Black Belt
As I explained in response to your prior posting (https://software.intel.com/en-us/forums/intel-math-kernel-library/topic/658660), threads are not going to help here -- the FFT performance will be limited by the data transfer time to/from the Xeon Phi.
For thread-level parallelization internal to the MKL routines, you can use the MKL_NUM_THREADS environment variable.  This allows you independent control of the thread-level parallelism of your code (using OMP_NUM_THREADS) and the thread-level parallelism used by the MKL routines.  This should work for the MKL FFTW3 interfaces as well.
McCalpinJohn
Black Belt
There are also examples of using OpenMP parallelism with the MKL FFT interfaces at
https://software.intel.com/en-us/node/471392#FE027A11-6E44-42DF-8A56-5075E24CA22A
