Software Archive
Read-only legacy content
17060 Discussions
How to delete iOS 8.0.1 update?
Alejandro_J_
How to delete iOS 8.0.1 update download from your device to avoid accidental installation?
Adrian_Stevens
Unfortunately it's no long possible to downgrade from iOS 8 to iOS 7 - Apple is no longer signing the iOS 7 images so won't be able to manually install the older images.
Ali_k_2
Let me know about this error, please check this url a complete guideline to remove IOS update. Link
Akhil_R_
Step 1: Go to Settings > General > Usage > Manage Storage.
Step 2: Select “iOS 8.0.1.” Because it is over 1GB, it is probably towards the top of your list.
Step 3: Tap Delete Update, and tap Delete Update again to confirm.
This will effectively remove the downloaded update from your device and prevent you from accidentally installing it.
yaswanth_k_
better way to degrade ios is to jailbrake and re-install software , you can get get the available versions of ios(7  6 8)
