Hi
I downloaded appframework-templates (appframework3) template from GITHUB
(https://github.com/krisrak/appframework-templates#sample-app-created-from-templates) and I paste it content in my "www" folder. When I emulating it show correct output and build complete successfully but when I am installing apk file on android phone app is not installing. If installed it's not opening. All I want to open framework 3 on my phone.
What is difference between ARM base apk file and X86 base apk file? When I download file after successful build, intel xdk these download two files.
I am using :
Intel Xdk version 3400
Cordova CLI version 5.1.1
Testing apk file on Android 5.1.1
- Tags:
- HTML5
- Intel® XDK
Those templates are built into the XDK on the "Start a New Project" page. I recommend you create your project using those layout templates that are built into the XDK, rather than the process you described in your post.
When you build with Crosswalk, which was the case you describe in your post, you will get two APK files. Please see the documentation for details > https://software.intel.com/en-us/xdk/docs/lp-crosswalk <
