Software Archive
Read-only legacy content
17060 Discussions
How to use Unity?
Kiriakos_T_
I am interesting to use Intel RealSense SDK and I would like to create some projects in Unity using the RealSense SDK. So I have already downloaded the SDK, and I tried to use the Unity's examples. To be more specific I tried to use NineCubes example but I didn't have the results which I want. The result is the following:
MartyG
Whilst I do not have a solution for your particular problem with the NineCubes example, if you are looking to learn to use Unity in general then you may find it helpful to read the developer diaries of my company's previous Unity projects, which document each step in deep detail with illustrations, from initial idea to finished project.
You can find our previous two projects 'The Golden Hour' and 'Sampathy' (our 2013 perceptual computing entry, which deals with camera code) on our developer hub page.
http://sambiglyon.org/?q=node/641
Colleen_C_Intel
The unity lib in ninecubes turns out to be an older version than in the rest of the SDK.   You might look at libpxccpp2c files in the SDK and see if it makes any difference.
