Software Archive
Read-only legacy content
17060 Discussions
How to use the cilkview?
Lawrence_R_
I have a C search application  on a centos 6.x 64 bit linux server that I just installed the cilkplus compiler on to take advantage of more cpu/cores. I've added the cilk_spawn function to some recursive scanning functions in my program.  After re-compiling the search application with the cilkplus gcc compiler, the search program is working as intended without any seg faults or any other errors.
My question is how do I use the cilkview analyzer? I want to if cilkplus/spawning is helping my search application and if so by how much?
Thanks!
Lawrence
Barry_T_Intel
When you installed the Cilk Tools, there should have been a "doc" directory containing cilktools.html.  It should explain how to run Cilkview and how to interpret the output. Is this documentation insufficient?
   - Barry
Lawrence_R_
Hi Barry,
Thanks for the quick reply!  Is the cilk tools a separate item to install outside of the gcc compiler?  I did a search for the doc directory and this is all I have on the server:
/cilkplus/boehm-gc/doc
/cilkplus/zlib/doc
/cilkplus/x86_64-unknown-linux-gnu/libstdc++-v3/doc
/cilkplus/libstdc++-v3/doc
/cilkplus/gcc/doc
/cilkplus/prev-x86_64-unknown-linux-gnu/libstdc++-v3/doc
/cilkplus/stage1-x86_64-unknown-linux-gnu/libstdc++-v3/doc
/cilkplus/host-x86_64-unknown-linux-gnu/prev-gcc/doc
/cilkplus/host-x86_64-unknown-linux-gnu/gcc/doc
/cilkplus/host-x86_64-unknown-linux-gnu/stage1-gcc/doc
/cilkplus/libffi/doc
/cilkplus/libgo/go/go/doc
/cilkplus/libjava/classpath/doc
Barry_T_Intel
Yes. The Cilk Tools are available from the Download page of the Cilk Plus website: http://www.cilkplus.org/download
You'll find them referred to as the "Intel Cilk Plus SDK."
   - Barry
Lawrence_R_
Hi so I downloaded the cilk tools and perused the cilktools.html#CilkviewAssumptions and when I try and run the cilkview on my system I get the following error:
$ cilkview ./search
cilkview: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
Currently I have the cilk tools on my root directory:
/root/cilktools-linux
/root/cilktools-linux/bin/cilkview
So I understand that the error is related to some kind of missing path or not seeing the correct location of the file needed.  Currently I have the following locations for libstdc++.so
$ find / -name libstdc++.so
/usr/lib/gcc/x86_64-redhat-linux/4.4.4/32/libstdc++.so
/usr/lib/gcc/x86_64-redhat-linux/4.4.4/libstdc++.so
/opt/centos/devtoolset-1.1/root/usr/lib/gcc/x86_64-redhat-linux/4.7.2/32/libstdc++.so
/opt/centos/devtoolset-1.1/root/usr/lib/gcc/x86_64-redhat-linux/4.7.2/libstdc++.so
/cilkplus/cilkplus-install/lib64/libstdc++.so
/cilkplus/x86_64-unknown-linux-gnu/libstdc++-v3/src/.libs/libstdc++.so
/cilkplus/prev-x86_64-unknown-linux-gnu/libstdc++-v3/src/.libs/libstdc++.so
/cilkplus/stage1-x86_64-unknown-linux-gnu/libstdc++-v3/src/.libs/libstdc++.so
How can I resolve this issue?
Thanks for all the help you guys have shown over the last couple of days!
Lawrence_R_
in my bashrc file I have the following:
export PATH=/cilkplus/cilkplus-install/bin:$PATH
export CPATH=/cilkplus/cilkplus-install/include:$CPATH
export LIBRARY_PATH=/cilkplus/x86_64-unknown-linux-gnu/libcilkrts/.libs/:/cilkplus/cilkplus-install/lib:/cilkplus/cilkplus-install/lib/../lib64:$LIBRARY_PATH
export LD_LIBRARY_PATH=/cilkplus/x86_64-unknown-linux-gnu/libcilkrts/.libs/:/cilkplus/cilkplus-install/lib:$/cilkplus/cilkplus-install/lib/../lib64:$LD_LIBRARY_PATH
export PATH=/root/cilktools-linux/bin:$PATH
Lawrence_R_
Also I have previously installed the clikplus on my mac.  I tried to test out the cilkview there and got a curious error:
/Users/cilkm2search/dev/app/cilktools/bin/cilkview  test
root_dir: /Users/cilkm2search/dev/app/cilktools/
Cilkview: Generating scalability data
Cilkview Scalability Analyzer V2.0.0, Build 3566
Error: No Cilk code found in program
However the test program is just the basic fib example with cilk_spawn and cilk_sync:
#include <cilk/cilk.h>
#include <assert.h>
int fib(int n) {
  if (n < 2)
    return n;
  int a = cilk_spawn fib(n-1);
  int b = fib(n-2);
  cilk_sync;
  return a + b;
int main() {
  int result = fib(30);
  assert(result == 832040);
  return 0;
Also cilk is working though in the program:
unknown68a86d1de446:test lawrence$ CILK_NWORKERS=4 time ./test
        0.04 real         0.15 user         0.00 sys
unknown68a86d1de446:test lawrence$ CILK_NWORKERS=1 time ./test
        0.10 real         0.10 user         0.00 sys
Lawrence_R_
Lawrence_R_
Barry_T_Intel
Hi Lawrence.
I'm glad to hear that you've resolved your problems on CentOS.
The message "Error: No Cilk code found in program" means that Cilkview (and Cilkscreen) didn't see any metadata. Which compiler are you using?
   - Barry
Lawrence_R_
For my mac which was getting the error message about not finding the cilk meta data, I followed these instructions here:
"An implementation of the Intel® Cilk™ Plus C/C++ language extensions in LLVM"
http://cilkplus.github.io/
Barry_T_Intel
Ah! Cilk Plus/LLVM is known to not be generating metadata.
I recommend that you post a bug about it. At the bottom of http://cilkplus.github.io/ there are directions to report bugs or make feature requests at https://github.com/cilkplus/clang/issues .
    - Barry
