Software Archive
Read-only legacy content
17060 Discussions
IOS build Multitasking support orientation error uploading to itunes
Rex_C_
Need a hand on this issue hoping you could help me.
Never had this error before, until today when uploading my build to itunes. (please see image below)
I tried fixing it by checking "Fullscreen" on build settings
tried orientation to landscape and portrait.  And the wierd thing is when i select 'default' or 'All' for the orientation the upload will say
"Found '$availableValues'" (see the highlight from the image above)
I use windows on building and mac for uploading to itunes.
I would love to here some response.
John_H_Intel2
Fix has been confirmed on production servers. You will need to rebuild your code and then reupload the ipa with application loader.
John_H_Intel2
We upgraded the build servers xCode to 7 yesterday, yeah!
Thanks for letting us know about this, we are working on a fix now. Will post back when its ready to go.
Rex_C_
i also tried adding lines below to additions.xml but doesnt work still
<config-file target="*-Info.plist" parent="UISupportedInterfaceOrientations~ipad">
    <array>
         <string>UIInterfaceOrientationPortrait</string>
      <string>UIInterfaceOrientationPortraitUpsideDown</string>
    </array>
</config-file>
<config-file target="*-Info.plist" parent="UIRequiresFullScreen">
     <true/>
</config-file>
Daniel_B_10
same problem (Belgium)
John_H_Intel2
Daniel_B_10
ok, thanks , a new build was accepted
Rex_C_
AWESOME thanks for the fix!!
