When i tip the URL direct in InAppBrowser script code, the "done Button"and toolbar appear inside InAppBrowser view.
But if script receives the URL by an expression (variable) the InApp don't shows the buttons and bars...
Someone had this kind of problem before?
- Tags:
- HTML5
- Intel® XDK
Hi Marcos N.
I think the problem is in the code. From the image you posted, I see that you have an additional "+" sign before "_blank".
cordova.InAppBrowser.open(valor, + '_blank', 'location=yes');
can you try removing that additional "+" sign and try again?
TO begin.... Really thanks for answer so quickly. And then... i`m so shame.. its run!! It was so simple and i don't saw... THANKY you NICO.
No Problem Marcos N.!
This kind of errors are really common on Javascript code. There are several tools (jshint, eslint) that helps you with this Checkings. The XDK support xlint and jshint in the Editor.
You can see here how to configure it https://software.intel.com/en-us/xdk/docs/using-the-editor-in-the-develop-tab (Section "Configure JSHint")
