Hi there!
I have update to Intel XDK 3240 a few days ago, I rebuilt my application, but when I try to open on device, I am getting the message:
Incomplete Crosswalk Project Service Please repackage Nodirtyenv.
I closed XDK, removed the plugin folder, and rebuilt the application and still getting the same error message. Any help?
- Tags:
- HTML5
- Intel® XDK
Perhaps you are trying to install the resulting file is not under its own processor architecture. X86 or ARMv7. Check your CPU architecture
Did you make sure the "sign app" box is set? Very strange error, never seen that before. Try building with CLI 5.4.1.
Jonas -- I think Roman is correct. See this thread > https://software.intel.com/en-us/forums/intel-xdk/topic/632221
I think it will not help. Version CLI - this problem has not much value. Most likely, because the Plugins folder was removed - a mistake on the processor architecture or in Plugins.
Hi guys!
Problem solved!
I was downloading the x86 file to my device instead of ARMv7. I unchecked "Optimize with Crosswalk" to generate just a file to development. Checked "Optimize with Crosswalk" back to generate both files to send to Google play. Thanks.
