Software Archive
Read-only legacy content
17060 Discussions
Installing Fortran 9.1 using silent install
wmusinski3
Hello all,
I have the same issue with downloading an earlier version of Fortran Compiler 9.1 as described in "License Issues for Old versions of intel fortran and c++ compilers" topic #68054. I followed the directions in the "silent_install_guide_linux_12_2007.doc" and received the following error.
"trap: 4021: SIGINT: bad trap"
Please help. Thanks!
Lina_L_Intel
Quoting - wmusinski3
Hello all,
Greetings,
If you have not already done so, please do the steps in the article on how to install older versions at
http://software.intel.com/en-us/articles/older-version-installation/.
Please let us know if this helps.
Thank you.
Lina
wmusinski3
Greetings,
Thank you.
Lina
I have tried this and it did not work. My problem is identical to the one that is referenced above. I am to the point of silent install when I received the above error message.
Thanks for your help!
Chuck
New Contributor II
Greetings,
Have you read the article at the following?
http://software.intel.com/en-us/articles/intel-compilers-for-linux-silent-installation-guide/
Chuck
New Contributor II
There is more information available for Silent Installs at:
http://software.intel.com/en-us/articles/intel-compilers-for-linux-version-111-silent-installation-guide/
This article explains the Silent Install for Version 11.1. It also states that silent installs for versions prior to 11.1 are no longer supported.
Can you upgrade to the 11.1 product?
Chuck
