I have an android app. The app is basic in its functioning .
I decided to add native code to this app. So I put a square function ( C code ) inside jni folder and compiled it . This shared library I used in the android app and it works ok.
I was given a statically ICC compiled library that does something similar and asked to use it also .
Then with Intel INDE installed already I decided to use the ICC for compiling the ndk part . So I followed the following link.
Though I should be using the Android Studio...I worked with eclipse and NDK builder to compile first just the shared library without making reference to the static libraries api ..to check if my original program does work with ICC. It worked ok
Then I made a reference to the api in the static library that I had been given and compiled the whole program again with ICC this time prelinking the static library along and using the NDK Builder to generate my shared library that I will refer in the android app. This ran into run time error
I took the tombstone trace and see that the function referred in the prelinked static library is missing
I noticed that the icc when I ran ndk-build V=1 at the very end removed this function reference and I believe the crash is due to this . I can share the code if you want to have a look at the way I am trying this out
<code>
C:/Android/ndk-r10d/toolchains/x86-4.8/prebuilt/windows-x86_64/bin/i686-linux-android-strip.exe --strip-unneeded ./libs/x86/libjni_example.so
</code>
- Tags:
- Android* OS
After compiling with this Android.mk file in the jni foilder , should'nt I get the shared library which includes the prelinked static library ?
include $(CLEAR_VARS)
#NDK_PROJECT_PATH = C:\Users\kuvineet\workspace\alarm\alarm\
LOCAL_MODULE := X_prebuilt
LOCAL_SRC_FILES := ./path_for_X/libX.a
LOCAL_EXPORT_C_INCLUDES := $(LOCAL_PATH)/gnss
include $(PREBUILT_STATIC_LIBRARY)
LOCAL_MODULE := Y
LOCAL_C_INCLUDES := $(LOCAL_PATH) \
$(LOCAL_PATH)/path_for_X
LOCAL_SRC_FILES := y.cpp
LOCAL_STATIC_LIBRARIES := X_prebuilt
LOCAL_LDLIBS := -llog
include $(BUILD_SHARED_LIBRARY)
I got the library libY.so of size less than the library size of libX.a .What is wrong with this method of creating a shared library to include a pre-linked static library ?
