Software Archive
Read-only legacy content
17061 Discussions
Intel CE4100 SDK building
brandintel
I am following the steps given in Intel CE Media processors document.
After installation of ISOs, i am using make menuconfig to build the SDK.
In that menu Kernel selection menu item is there, which i selected as none. There are two other options available in the selection menu. what is the significance of this?
When i selected linux as my kernel i am unable to build my SDK successfully. So i selected none.
I tried to build an example application generated with above SDK build tool chain(Kernel as NONE).
Can i assume that my executable runs on actual hardware ?
Thanks in Advance
BrandIntel
Igor_V_Intel
Dear customer,
You posted this question in Download, Registration and Licensing forum.
However, it looks like a technical question - not a licensing. Could you please ask your question on the corresponding forum?
Igor
