Software Archive
Read-only legacy content
17060 Discussions
Intel Edison spi read error
Stefan_V_
i tried out libmraa with iot - spi write works fine, lacks a little of perdormance.
I have problems reading from spi - because i always get a copy of the content of the write buffer in the read buffer. I have verified, that the data on receive line is different. I can track it down to libmraa. Libmraa uses the same call into iot for write, write_buf and transfer_buf - so all functions don't work for reading spi. I always get back a copy of the transmit buffer. Maybe for reading the content of the transfer-buffer register is read out instead of the receive-register.
Because low level registers of Intel Edison are documented so purely, i cannot track it further.
Could you check this please ?
Stefan Verse
NagaVenkat_K_Intel
Created an issue in github. Please refer https://github.com/intel-iot-devkit/mraa/issues/82.
