Software Archive
Read-only legacy content
17060 Discussions
Intel.SoftwareManager package doesn't load correctly; MSVC 2010
AARON_K_Intel
We're running devenv.exe from within cygwin, and get the following message when starting Visual Studio 2010:
"The 'Intel.SoftwareManager.IsmPkg,Intel.SoftwareManager,Version=1.0.0.4...' package did not load correctly." The rest of the dialog suggests examining ActivityLog.xml.
The error from ActivityLog.xml reads:
<record>65</record>
    <time>2013/10/03 00:20:48.829</time>
    <type>Error</type>
    <source>VisualStudio</source>
    <description>SetSite failed for package [Intel.SoftwareManager.IsmPkg, Intel.SoftwareManager, Version=1.0.0.4, Culture=neutral, PublicKeyToken=338423d0c6ec8b0d]</description>
    <guid>{0EB46392-119D-44D1-A0BE-C67AFDDDDA6E}</guid>
    <hr>80004003 - E_POINTER</hr>
    <errorinfo>Value cannot be null.
Parameter name: path1</errorinfo>
Is there a way to resolve this issue?
Bernard
Valued Contributor I
It looks as a null pointer and that hex address could be the address of the culprit or error code.
AARON_K_Intel
Right. 0x80004003 is the MS return code for invalid pointer. The problem is that I don't have any more visibility into what's happening. I was hoping that someone could shed some insight on what to look for to resolve this, such as the parameters that SetSite is using, and the source of those parameters.
Thanks, Aaron
Bernard
I also do not know how to start troubleshooting this.
Kirill_R_Intel
AARON K., if you still experience the problem, please submit an issue to premier.intel.com.
AARON_K_Intel
Will do, thank you.
