I am trying to configure the debug registers in the host so that I can monitor an address of a guest running on Intel VT-x. For this I have called KVM_SET_GUEST_DEBUG IOCTL.
struct kvm_guest_debug guest_debug; guest_debug.control = KVM_GUESTDBG_ENABLE | KVM_GUESTDBG_USE_HW_BP; guest_debug.arch.debugreg[0] = addr; // DR0 guest_debug.arch.debugreg[7] = encode_dr7(0, len, bpType); if (ioctl(vcpu_fd, KVM_SET_GUEST_DEBUG, &guest_debug) < 0) return false;
It successfully sets up the debug register. But upon debug register read/write, it causes VM_EXIT with EXIT_REASON_EXCEPTION_NMI. Although I am expecting to have EXIT_REASON_DR_ACCESS. What is the reason that causes an nmi exit instead of DR_ACCESS exit? Did I set the registers right?
- Tags:
- Virtualization
Topic Options
