Software Archive
Read-only legacy content
17060 Discussions
Intel XDK 3088 Cordova Signatur Conflict
Christian_K_
i have updated to Intel XDK 3088 and add my keystore developer certificate to my app.
I can not install the App on my Smartphone, after the build process. I see the followed message.
Signatur conflict with the old App Version.
What can i do?
Swati_S_Intel1
Are you using the same keystore certificate as you used earlier for the same app? If you have used the default certificate to build the app earlier, you would have to go to account settings and convert the legacy certificate into the new certificate schema using the thick arrow and use that certificate.
Swati_S_Intel1
You have to extract the apk and need to use keytool to reveal the certificate.
If you built using Intel XDK earlier, it uses the default certificate. In the 3088 version, make sure you converted your "legacy certificate".
Swati_S_Intel1
You have to do it in the Intel XDK. Go to Account Settings (top right) and use the thick arrow. see below.
