Software Archive
Read-only legacy content
17061 Discussions
Intel XDK - Build failed
Abner_C_
I cannot build any proyect. I asked for a change to my keystore, and I think this may be the problem because of the log:
-release-nosign:
     [echo] No key.store and key.alias properties found in build.properties.
     [echo] Please sign .../TwitchCast/platforms/android/ant-build/CordovaApp-release-unsigned.apk manually
     [echo] and run zipalign from the Android SDK tools.
-release-sign:
release:
BUILD SUCCESSFUL
Total time: 12 seconds
Here is the complete log file: https://drive.google.com/open?id=0B2JBNspfO2NiNGFabERlTzducVk&authuser=0
John_H_Intel2
Its possible your keystore got fubared during the import. Can you REsend the keystore and the necessary info that is required to import it to your account to html5tools@intel.com?
Abner_C_
I just did yesterday. I guess i'll have to keep waiting :(
Thank you.
Pamela_H_Intel
Abner,
Did you get what you needed? I checked the email box and do not see any email from you.
Meanwhile, one issue people are having is build failure or store submission failure when the create their new keystore with non-ASCII characters or spaces in the alias (in version 3088). If that is the case (you have some special charaters like Ñ ã ô ü á), you can change your alias by following the instructions in the following FAQ:  https://software.intel.com/en-us/xdk/faqs/cordova#change-keystore-alias. Otherwise, please tell me which XDK version you are using and whether you have converted your legacy keystore.
Pamela
Abner_C_
Yes, i send an email to html5tools@intel.com and my problem was resolved shortly after.
Thank you.
