My computer has a xeon phi coprocessor. I get an error No mic cards found or specified in command line. I am using mpss 3.8.2. My kernel is 2.6.32-696.6.3.el6.x86_64. I have rebuild the kernel modules using source. I also tried reistalling mpss. When I run micrasd command error given is
Wed Jul 26 09:41:18 2017 MICRAS INFO : Open MCA filter log history.
Wed Jul 26 09:41:18 2017 MICRAS ERROR : No MIC device detected!
Some specs of your computer would help here:
does your computer have a first generation Xeon Phi (x100 series) PCIe adapter? for those you'd need the MPSS 3.8.2 stack. For the Xeon Phi x200 (aka Knight's Landing) you do NOT need the MPSS stack.
My computer have a first generation a Xeon phi x100 series PCIe adapter
hmmm why not install the supplied package (mpss-modules-2.6.32-696.el6.x86_64-3.8.2-1.x86_64) ? this will set up a "weak link" that will load the module in the 696.6.3.el6 kernel without any issues.
Also. check that the module can be loaded
$ modprobe mic
what error did it produce?
OK, now check that the module is loaded and start the mpss daemon:
$ lsmod | grep mic $ service mpss start
then check that the card can be found:
$ micinfo
Please post the output, or post the output of 'micdebug.sh' here.
