Software Archive
Read-only legacy content
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
17065 Discussions
Ionic Slide-box
Mario_R_
Hello to all,
I'd need help using the example of the Ionic slide-box within an Ionic project Framwork.
The example can be found at this link: http://ionicframework.com/docs/api/directive/ionSlideBox/
I tried to put the simple example on a page, but does not display anything. Could you help me thank.
Amrita_C_Intel
Can you send your .zip file of your project?
Pamela_H_Intel
Mario - be aware that the slide box has been deprecated and will not be available in the next release. The Ionic folks recommend using the ion-slides instead: http://ionicframework.com/docs/api/directive/ionSlides/
Mario_R_
Here is the project in zip, I have included three examples:
  1. Simple slide-box;
  2. Example on the above page
  3. New slide method
I'm probably wrong approach, thanks for the help.
Mario_R_
Some news?
Thank you
Amrita_C_Intel
As Pamela mentioned that slide box has been deprecated. I would highly recommend that you might need to start looking for the alternative.
Amrita_C_Intel
Hello Mario,
Are you testing on the device or emulator?
Is it showing any error message?
