Software Archive
Read-only legacy content
17060 Discussions
Ionic Slide-box
Mario_R_
Hello to all,
I'd need help using the example of the Ionic slide-box within an Ionic project Framwork.
The example can be found at this link: http://ionicframework.com/docs/api/directive/ionSlideBox/
I tried to put the simple example on a page, but does not display anything. Could you help me thank.
Amrita_C_Intel
Can you send your .zip file of your project?
Pamela_H_Intel
Mario - be aware that the slide box has been deprecated and will not be available in the next release. The Ionic folks recommend using the ion-slides instead: http://ionicframework.com/docs/api/directive/ionSlides/
Mario_R_
Here is the project in zip, I have included three examples:
  1. Simple slide-box;
  2. Example on the above page
  3. New slide method
I'm probably wrong approach, thanks for the help.
Mario_R_
Some news?
Thank you
Amrita_C_Intel
As Pamela mentioned that slide box has been deprecated. I would highly recommend that you might need to start looking for the alternative.
Amrita_C_Intel
Hello Mario,
Are you testing on the device or emulator?
Is it showing any error message?
