I built an app for iOS with Cordova 4.2.1 (and then tried 5.1.1 also) ,created certificate and the provisioning files folllowing the instructions below :
http://www.html5dev-software.intel.com/amdocs/lib/Walkthrough_v1_UploadCSR-ObtainCert.pdf
http://www.html5dev-software.intel.com/amdocs/lib/Walkthrough_v3_CreateDistProvProfile.pdf
It failed but when i checked the error log (the file is attached) i got 'Build Succeeded' message with error code 0.
Do you have any idea regarding this issue?
- Tags:
- HTML5
- Intel® XDK
There is currently a bug with Cordova that if the app name and project name are identical, it will fail to build.Try changing your App Name and see if that allows it to build. We should have a patch for this in the near future.
Yes It works!
Thanks for your help John.
