Software Archive
Read-only legacy content
17060 Discussions
Issue with XDK plugin deletion
Michel_K_
I'm blocked by a build failure after the deletion of several plugins which aren't needed by my app (last update 2496, Cordova Androïd build).
The three concerned XDK plugins (base, camera and device) remain in the list after I deleted them. When I try to suppress them again, I get the following message  : " Remove modified plugins ?", although I didn't modify them.
When I click then on "Continue", the answer is  : "Unknown error. ENOENT no such file or directory  [...]"
Three screenshots are attached.
Thank you for your help.
John_H_Intel2
We are aware of a couple bugs with the plugins in the newest XDK. Until we release a new version, the simplest way for you to get back up and running is to create a new project, and copy your files/settings to it, then try building again.
