Software Archive
Read-only legacy content
17060 Discussions
It is possible to modify the Scanning area (R200)
Gerardo_M_
Hello, I have been using the F200 camera since several months ago, now I got a R200 camera, however I found that the Scanning area in both cameras are quite different. I want to know if it is possible to modify the Scanning area variables type, width, height, etc. I'm using R200 with the 3D scan example developed in C#.
samontab
Valued Contributor II
If you mean the region of space that you see in each camera, then, no. That is determined by the sensor size and the lens focal length, both of which you can't really change in these cameras.
Gerardo_M_
Actually I'm talking about the 3D cube that the camera virtually makes during the Scanning process. For example, when I scan a Head I have a virtual cube that the camera makes to capture the imagine, my understanding is that the camera has the following parameters (just an example):
width: X
Height : Y
Depth : Z
Distance: 1mt.
It is possible for me to change those values to another ones that better fits my needs, for example:
width: X-A
Height : Y-A
Depth : Z-A
Distance: 0.5 mt.
Where A is a value I can enter.
samontab
jb455
Have the available functions changed? None of those on the link seem to be able to modify the scanning volume, unless I'm missing something..
