Software Archive
Read-only legacy content
17060 Discussions
JAVASCRIPT doesn't work anymore ! Help !
henry_p_1
Hello everebody,
I work XDK 1878 on ubuntu.
Since the upgrade, the javascript code is no more executed ! Nothing at all !
I am fully bloked and can't do anything more on my development.
I try just a program with just an alert in javascript, it doesn't work !
The same in Firefox work perfectly.
Can somebody help  ?
Thanks...
John_H_Intel2
Do you have any errors in the emulator debug console?
Can you post your index.html file?
henry_p_1
Hello..
This is the code I ask to execute (cordova project):
<!DOCTYPE html>
<html>
<head>
    <title>Blank Cordova App Project Template</title>
    <meta http-equiv="Content-type" content="text/html; charset=utf-8">
    <meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1, user-scalable=no">
    <link rel="stylesheet" href="css/app.css">
</head>
<body>
    <h1 class="align-center">A Blank Project Template</h1>
    <p class="align-center">
        To use this template as a starter app, start with init-app.js and app.js for your JavaScript code.
        See the README.md file for more details and the comments inside index.html, app.js and init-app.js.
    </p>
    <br>
        <input type="button" id="id_btnHello" value="Touch Me">
    </p>
    <script src="cordova.js" id="xdkJScordova_"></script>
    <script src="js/app.js"></script>           <!-- for your event code, see README and file comments for details -->
    <script src="js/init-app.js"></script>      <!-- for your init code, see README and file comments for details -->
    <script src="xdk/init-dev.js"></script>     <!-- normalizes device and document ready events, see file for details -->
</body>
    <script>
    alert ("hello");
    </script>
</html>
and this is the console output:
Console was cleared /home/henry/intel/XDK/xdk/components/client/emulator/ripple.js:25867
This same code work perfectly on Netbeans, and on all ohers EDI, but not with XDK.
I have the same problem with all my app since the update: nothing work anymore !
Thanks for ur help...
Chris_P_Intel
For me your code works fine.  However, I should note that your <script> should go _inside_ the body tag, not outside.
henry_p_1
Hello...
Yes, you're right, but for this test is it not important.
I can't understand why this code won't work on XDK but work well on Netbeans.
I have tried to reinstall XDK but no way...
There is someting somewhere but I can't find the problem.
Is there a bug with the new version on XDK for ubuntu ?
That's what I think... Are you working on Windows ?
henry_p_1
Hello...
Sorry for my english...
I have installed a new Windows and I can work with Javacript now.
Nobody from Intel answer here but I think there is a bug with the Ubuntu version.
Now all the code I write work perfectly when I don't use XDK. A simple geolocalisation doesn't work in XDK (I take an example from Intel and It doesn't work !). I have the problem since one month and I can't solve it.
All the code I writed before the new release doesn't work anymore in the wen release ! But It worked perfectly before the upgrade; I'am sure of this !
No I stop with XDK.
I need something more seriously that this...  Too much bug and too mutch incompatibilities. No help enought. Too much problem.
John_H_Intel2
I just create a new project from the geolocation template, didnt change anything in the code, opened the emulator, and it worked just as it should.
