Hello to all,
I have a problem with speech recognition in Java.
I have successfully created a AudioSource and implementation of PXCMSpeechRecognition but when I try to call the function PXCMSpeechRecognition.StartRec, an exception occurs
java.lang.NoSuchMethodError: OnRecognized
If I try to add a function OnRecognized within my handler works but the callback is invoked only OnAlert
Can someone please help me ?
Can you give us details about your handler?
Did you get the prototypes like in this example ?
class MyHandler implements PXCMSpeechRecognition::Handler {
public void OnRecognition(PXCMSpeechRecognition.RecognitionData data) {
//process data
Thanks Xavier,
Yes, but there is also OnAlert function.
My Handler is
public void OnAlert(PXCMSpeechRecognition.AlertData data)
/////////////////// and i call StartRec
recognitionEngine.StartRect(source, new MyHandler());
When i call StartRec, i have an exception "java.lang.NoSuchMethodError: OnRecognized "
I had a look at the C ++ code, and actually he looks for a function called OnRecognized.
Indeed, if added, only for testing purposes, the function inside my handler:
public void OnRecognized(PXCMSpeechRecognition.RecognitionData data)
Works but i received only OnAlert callbacks....
Obviously the test I did was just to figure out what the problem was...
I hope I was clear and sorry for my English :)
Alessio
Thanks for the additional info.
Indeed it seems there is a typo in the c++ wrapper for Java (C:\Program Files (x86)\Intel\RSSDK\framework\common\pxcclr.java\)
While we're fixing it, you can search and replace all occurences of "nRecognized" by "nRecognition" inside pxcmspeechrecognition.cpp, recompile the project and replace libpxcclr.*.dll for your project.
Thanks Xavier,
I loaded the project libpxcclr.jni_vs2010 and i have edited the pxcmspeechrecognition.cpp
I have change the line
AsyncCallback OnRecognizedCb(true, "OnRecognized", "(Lintel/rssdk/PXCMSpeechRecognition$RecognitionData;)V");
with
AsyncCallback OnRecognizedCb(true, "OnRecognition", "(Lintel/rssdk/PXCMSpeechRecognition$RecognitionData;)V");
And i have recompiled the DLL
Now, there isn't any exception on StartRec but the OnRecognition callback is never invoked.
I have seen that in StartRec function on cpp file use an SRHandler wrapper. This handler call invoke on OnRecognizedCb when an OnRecognition occurs from the recognition engine.
Alessio
Inside pxcmspeechrecognition.cpp, you need to change the other occurences of nRecognized too, more specifically to rename SRHandler::OnRecognized in SRHandler::OnRecognition
Xavier thanks for your patience.
I did all the substitutions and no exceptions occur when i call the StartRec
But now, when the in the moment to invoke the OnRecognition, it takes a crash of the virtual machine
I have recompiled the DLL with x64 in release mode.
Also, I give you another clue, when the ALERT_SPEECH_END alert occurs, application crash with JVM exception
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000007fef7e868d4, pid=3828, tid=5896
# JRE version: Java(TM) SE Runtime Environment (8.0_60-b27) (build 1.8.0_60-b27)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.60-b23 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [libpxcclr.jni64.dll+0x68d4] Registration::~Registration+0x84
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x0000000055e8b000): VMThread [stack: 0x0000000056ee0000,0x0000000056fe0000] [id=5896]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000000000000b0
Registers:
RAX=0x0000000000000000, RBX=0x000000005b265690, RCX=0x0000000055e8b1f8, RDX=0x0000000058158f08
RSP=0x0000000056fdf260, RBP=0x0000000055d75400, RSI=0x0000000000000000, RDI=0x00000000ffffff01
R8 =0x0000000000000000, R9 =0x0000000000000000, R10=0x0000000056fdf2a8, R11=0x0000000056fdf378
R12=0x00000000003cc5e0, R13=0x0000000000000040, R14=0x00000000003cc650, R15=0x0000000056fdf360
RIP=0x000007fef7e868d4, EFLAGS=0x0000000000010202
Top of Stack: (sp=0x0000000056fdf260)
0x0000000056fdf260: 0000000055d75400 000007fef7f02200
0x0000000056fdf270: 000000005b265690 000000003d00003d
0x0000000056fdf280: fffffffffffffffe 00000000003cff00
0x0000000056fdf290: 000000005b265690 000007fef7e86790
0x0000000056fdf2a0: 000000005b230640 0000000055e8b1f8
0x0000000056fdf2b0: 000007fef7f02200 00000000003d0dd0
0x0000000056fdf2c0: 000007fef7ed38a0 000007fef7eb7993
0x0000000056fdf2d0: 00000000003cc648 00000000003cc5e0
0x0000000056fdf2e0: 0000000000000200 0000000000000001
0x0000000056fdf2f0: 00000000003cc648 00000000003cc5e0
0x0000000056fdf300: 00000000003cc5e0 00000000003cc650
0x0000000056fdf310: 0000000000000001 0000000000000000
0x0000000056fdf320: 000007fffffae000 000007fffffd7000
0x0000000056fdf330: 0000d4a3df016b4c 000007fef7eb7ea5
0x0000000056fdf340: 0000000000000000 0000000000000001
0x0000000056fdf350: 0000000000000000 0000000056fdf390
Instructions: (pc=0x000007fef7e868d4)
0x000007fef7e868b4: 24 48 eb 05 48 8b 4c 24 48 83 ff fe 40 0f 94 c7
0x000007fef7e868c4: 48 85 c9 74 31 48 8b 13 48 85 d2 74 12 48 8b 01
0x000007fef7e868d4: ff 90 b0 00 00 00 90 48 89 33 48 8b 4c 24 48 48
0x000007fef7e868e4: 8b 53 08 48 85 d2 74 0e 48 8b 01 ff 90 b0 00 00
Register to memory mapping:
RAX=0x0000000000000000 is an unknown value
RBX=0x000000005b265690 is an unknown value
RCX=0x0000000055e8b1f8 is an unknown value
RDX=0x0000000058158f08 is a global jni handle
RSP=0x0000000056fdf260 is an unknown value
RBP=0x0000000055d75400 is an unknown value
RSI=0x0000000000000000 is an unknown value
RDI=0x00000000ffffff01 is an unallocated location in the heap
R8 =0x0000000000000000 is an unknown value
R9 =0x0000000000000000 is an unknown value
R10=0x0000000056fdf2a8 is an unknown value
R11=0x0000000056fdf378 is an unknown value
R12=0x00000000003cc5e0 is an unknown value
R13=0x0000000000000040 is an unknown value
R14=0x00000000003cc650 is an unknown value
R15=0x0000000056fdf360 is an unknown value
Stack: [0x0000000056ee0000,0x0000000056fe0000], sp=0x0000000056fdf260, free space=1020k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [libpxcclr.jni64.dll+0x6790] AsyncCallback::~AsyncCallback+0x30
C [libpxcclr.jni64.dll+0x37993] __crt_seh_guarded_call<int>::operator()<<lambda_e24bbb7b643b32fcea6fa61b31d4c984>,<lambda_275893d493268fdec8709772e3fcec0e> & __ptr64,<lambda_9d71df4d7cf3f480f8d633942495c3b0> >+0x11b
C [libpxcclr.jni64.dll+0x37ea5] _execute_onexit_table+0x35
C [libpxcclr.jni64.dll+0x36aec] common_exit+0xf4
C [libpxcclr.jni64.dll+0xfbff] __scrt_dllmain_uninitialize_c+0x2b
C [libpxcclr.jni64.dll+0x1015e] dllmain_crt_process_detach+0x4e
C [libpxcclr.jni64.dll+0x10267] dllmain_dispatch+0xd3
C [ntdll.dll+0x23a81]
C [ntdll.dll+0x23890]
C [msvcr100.dll+0x20ccd]
V [jvm.dll+0x210a25]
V [jvm.dll+0x249747]
V [jvm.dll+0x2489e6]
V [jvm.dll+0x248e81]
V [jvm.dll+0x24909e]
V [jvm.dll+0x299f6a]
C [msvcr100.dll+0x21d9f]
C [msvcr100.dll+0x21e3b]
C [kernel32.dll+0x15a4d]
C [ntdll.dll+0x2b831]
VM_Operation (0x00000000589acbd0): Exit, mode: safepoint, requested by thread 0x0000000058117800
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0000000001fbd800 JavaThread "DestroyJavaVM" [_thread_blocked, id=220, stack(0x0000000002100000,0x0000000002200000)]
0x0000000058117800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=4340, stack(0x00000000588b0000,0x00000000589b0000)]
0x00000000580b8000 JavaThread "AWT-Shutdown" [_thread_blocked, id=2232, stack(0x0000000058bf0000,0x0000000058cf0000)]
0x00000000580b7800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=2096, stack(0x0000000058a80000,0x0000000058b80000)]
0x0000000057984000 JavaThread "Service Thread" daemon [_thread_blocked, id=5544, stack(0x0000000057d80000,0x0000000057e80000)]
0x000000005790b000 JavaThread "C1 CompilerThread2" daemon [_thread_blocked, id=5492, stack(0x0000000057700000,0x0000000057800000)]
0x0000000055ef7800 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=5880, stack(0x0000000057480000,0x0000000057580000)]
0x0000000055eef800 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=968, stack(0x0000000057800000,0x0000000057900000)]
0x0000000055efe000 JavaThread "Attach Listener" daemon [_thread_blocked, id=3368, stack(0x00000000575b0000,0x00000000576b0000)]
0x0000000055efc800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=5488, stack(0x0000000057330000,0x0000000057430000)]
0x0000000055e97800 JavaThread "Finalizer" daemon [_thread_blocked, id=3728, stack(0x0000000057060000,0x0000000057160000)]
0x0000000055e90800 JavaThread "Reference Handler" daemon [_thread_blocked, id=964, stack(0x0000000057190000,0x0000000057290000)]
Other Threads:
=>0x0000000055e8b000 VMThread [stack: 0x0000000056ee0000,0x0000000056fe0000] [id=5896]
VM state:at safepoint (shutting down)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x0000000001fbbfa0] Threads_lock - owner thread: 0x0000000055e8b000
Heap:
PSYoungGen total 28672K, used 8860K [0x00000000e0180000, 0x00000000e2180000, 0x0000000100000000)
eden space 24576K, 36% used [0x00000000e0180000,0x00000000e0a271a0,0x00000000e1980000)
from space 4096K, 0% used [0x00000000e1d80000,0x00000000e1d80000,0x00000000e2180000)
to space 4096K, 0% used [0x00000000e1980000,0x00000000e1980000,0x00000000e1d80000)
ParOldGen total 65536K, used 0K [0x00000000a0400000, 0x00000000a4400000, 0x00000000e0180000)
object space 65536K, 0% used [0x00000000a0400000,0x00000000a0400000,0x00000000a4400000)
Metaspace used 11180K, capacity 11354K, committed 11648K, reserved 1058816K
class space used 1443K, capacity 1541K, committed 1664K, reserved 1048576K
Card table byte_map: [0x0000000011890000,0x0000000011b90000] byte_map_base: 0x000000001138e000
Marking Bits: (ParMarkBitMap*) 0x000000006516a5b0
Begin Bits: [0x0000000012220000, 0x0000000013a10000)
End Bits: [0x0000000013a10000, 0x0000000015200000)
Polling page: 0x0000000000110000
CodeCache: size=245760Kb used=2373Kb max_used=2373Kb free=243386Kb
bounds [0x00000000024d0000, 0x0000000002740000, 0x00000000114d0000]
total_blobs=1098 nmethods=604 adapters=408
compilation: enabled
Compilation events (10 events):
Event: 8.073 Thread 0x000000005790b000 599 3 sun.java2d.loops.RenderCache$Entry::matches (30 bytes)
Event: 8.073 Thread 0x000000005790b000 nmethod 599 0x000000000271ff50 code [0x00000000027200c0, 0x00000000027202f0]
Event: 8.074 Thread 0x000000005790b000 600 3 java.awt.geom.AffineTransform::<init> (69 bytes)
Event: 8.074 Thread 0x000000005790b000 nmethod 600 0x000000000271fb10 code [0x000000000271fc80, 0x000000000271fe90]
Event: 8.074 Thread 0x000000005790b000 601 3 sun.java2d.SurfaceData::getTransparency (8 bytes)
Event: 8.074 Thread 0x000000005790b000 nmethod 601 0x000000000271f650 code [0x000000000271f7c0, 0x000000000271fa68]
Event: 8.190 Thread 0x000000005790b000 602 3 java.lang.Thread::interrupted (8 bytes)
Event: 8.190 Thread 0x000000005790b000 nmethod 602 0x000000000271f290 code [0x000000000271f400, 0x000000000271f588]
Event: 8.208 Thread 0x000000005790b000 603 ! 3 java.awt.EventQueue::postEventPrivate (104 bytes)
Event: 8.209 Thread 0x000000005790b000 nmethod 603 0x000000000271e450 code [0x000000000271e660, 0x000000000271eee8]
GC Heap History (0 events):
No events
Deoptimization events (5 events):
Event: 0.410 Thread 0x0000000058117800 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x000000000269fc4c method=java.util.HashMap.putVal(ILjava/lang/Object;Ljava/lang/Object;ZZ)Ljava/lang/Object; @ 56
Event: 0.415 Thread 0x0000000058117800 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x000000000269fc4c method=java.util.HashMap.putVal(ILjava/lang/Object;Ljava/lang/Object;ZZ)Ljava/lang/Object; @ 56
Event: 0.419 Thread 0x0000000058117800 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x000000000269fc4c method=java.util.HashMap.putVal(ILjava/lang/Object;Ljava/lang/Object;ZZ)Ljava/lang/Object; @ 56
Event: 0.445 Thread 0x0000000058117800 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x000000000269fc4c method=java.util.HashMap.putVal(ILjava/lang/Object;Ljava/lang/Object;ZZ)Ljava/lang/Object; @ 56
Event: 0.445 Thread 0x0000000058117800 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x000000000269eb00 method=java.util.HashMap.putVal(ILjava/lang/Object;Ljava/lang/Object;ZZ)Ljava/lang/Object; @ 56
Internal exceptions (10 events):
Event: 0.295 Thread 0x0000000001fbd800 Exception <a 'java/lang/ClassNotFoundException': ToolBar> (0x00000000e05b2bd0) thrown at
Event: 0.295 Thread 0x0000000001fbd800 Exception <a 'java/lang/ClassNotFoundException': ToggleButton> (0x00000000e05b3180) thrown at
Event: 0.295 Thread 0x0000000001fbd800 Exception <a 'java/lang/ClassNotFoundException': javax/swing/JToolBarSeparator> (0x00000000e05b35e0) thrown at
Event: 0.295 Thread 0x0000000001fbd800 Exception <a 'java/lang/ClassNotFoundException': ToolBarSeparator> (0x00000000e05b3a78) thrown at
Event: 0.296 Thread 0x0000000001fbd800 Exception <a 'java/lang/ClassNotFoundException': ToolTip> (0x00000000e05b41b8) thrown at
Event: 0.296 Thread 0x0000000001fbd800 Exception <a 'java/lang/ClassNotFoundException': Tree> (0x00000000e05b4dd8) thrown at
Event: 0.296 Thread 0x0000000001fbd800 Exception <a 'java/lang/ClassNotFoundException': Tree> (0x00000000e05b5518) thrown at
Event: 0.296 Thread 0x0000000001fbd800 Exception <a 'java/lang/ClassNotFoundException': javax/swing/JTreeCell> (0x00000000e05b5898) thrown at
Event: 0.297 Thread 0x0000000001fbd800 Exception <a 'java/lang/ClassNotFoundException': TreeCell> (0x00000000e05b5d20) thrown at
Event: 0.297 Thread 0x0000000001fbd800 Exception <a 'java/lang/ClassNotFoundException': RootPane> (0x00000000e05b6780) thrown at
Events (10 events):
Event: 8.226 loading class java/awt/LightweightDispatcher$2 done
Event: 9.217 Thread 0x0000000057ce0000 Thread added: 0x0000000057ce0000
Event: 9.217 Thread 0x0000000058422000 Thread added: 0x0000000058422000
Event: 9.217 Thread 0x0000000058422000 Thread exited: 0x0000000058422000
Event: 9.217 Thread 0x00000000581cb800 Thread exited: 0x00000000581cb800
Event: 9.218 loading class sun/java2d/pipe/hw/AccelDeviceEventNotifier
Event: 9.225 loading class sun/java2d/pipe/hw/AccelDeviceEventNotifier done
Event: 9.256 Thread 0x00000000580b9800 Thread exited: 0x00000000580b9800
Event: 9.325 Thread 0x0000000057ce0000 Thread exited: 0x0000000057ce0000
Event: 9.325 Executing VM operation: Exit
Dynamic libraries:
0x000000013f860000 - 0x000000013f897000 C:\Program Files\Java\jdk1.8.0_60\bin\java.exe
0x00000000773d0000 - 0x0000000077579000 C:\Windows\SYSTEM32\ntdll.dll
0x00000000771b0000 - 0x00000000772cf000 C:\Windows\system32\kernel32.dll
0x000007fefd4d0000 - 0x000007fefd53c000 C:\Windows\system32\KERNELBASE.dll
0x000007fefda30000 - 0x000007fefdb0b000 C:\Windows\system32\ADVAPI32.dll
0x000007fefd910000 - 0x000007fefd9af000 C:\Windows\system32\msvcrt.dll
0x000007fefe170000 - 0x000007fefe18f000 C:\Windows\SYSTEM32\sechost.dll
0x000007fefd690000 - 0x000007fefd7bd000 C:\Windows\system32\RPCRT4.dll
0x00000000772d0000 - 0x00000000773ca000 C:\Windows\system32\USER32.dll
0x000007fefe7d0000 - 0x000007fefe837000 C:\Windows\system32\GDI32.dll
0x000007fefdb30000 - 0x000007fefdb3e000 C:\Windows\system32\LPK.dll
0x000007fefd540000 - 0x000007fefd609000 C:\Windows\system32\USP10.dll
0x000007fefbc70000 - 0x000007fefbe64000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_fa3b1e3d17594757\COMCTL32.dll
0x000007fefd9b0000 - 0x000007fefda21000 C:\Windows\system32\SHLWAPI.dll
0x000007feff6b0000 - 0x000007feff6de000 C:\Windows\system32\IMM32.DLL
0x000007fefe460000 - 0x000007fefe569000 C:\Windows\system32\MSCTF.dll
0x0000000065630000 - 0x0000000065702000 C:\Program Files\Java\jdk1.8.0_60\jre\bin\msvcr100.dll
0x0000000064960000 - 0x00000000651e9000 C:\Program Files\Java\jdk1.8.0_60\jre\bin\server\jvm.dll
0x000007fef4f80000 - 0x000007fef4f89000 C:\Windows\system32\WSOCK32.dll
0x000007fefd860000 - 0x000007fefd8ad000 C:\Windows\system32\WS2_32.dll
0x000007fefdd20000 - 0x000007fefdd28000 C:\Windows\system32\NSI.dll
0x000007fefa7f0000 - 0x000007fefa82b000 C:\Windows\system32\WINMM.dll
0x000007fefc240000 - 0x000007fefc24c000 C:\Windows\system32\VERSION.dll
0x00000000775a0000 - 0x00000000775a7000 C:\Windows\system32\PSAPI.DLL
0x000000006e130000 - 0x000000006e13f000 C:\Program Files\Java\jdk1.8.0_60\jre\bin\verify.dll
0x0000000065cb0000 - 0x0000000065cd9000 C:\Program Files\Java\jdk1.8.0_60\jre\bin\java.dll
0x0000000065c90000 - 0x0000000065ca6000 C:\Program Files\Java\jdk1.8.0_60\jre\bin\zip.dll
0x000007fefe840000 - 0x000007feff5c9000 C:\Windows\system32\SHELL32.dll
0x000007fefdec0000 - 0x000007fefe0c3000 C:\Windows\system32\ole32.dll
0x000007fefd190000 - 0x000007fefd19f000 C:\Windows\system32\profapi.dll
0x0000000065490000 - 0x0000000065628000 C:\Program Files\Java\jdk1.8.0_60\jre\bin\awt.dll
0x000007feff5d0000 - 0x000007feff6a7000 C:\Windows\system32\OLEAUT32.dll
0x000007fef4530000 - 0x000007fef45af000 C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll
0x000007fefd020000 - 0x000007fefd02f000 C:\Windows\system32\CRYPTBASE.dll
0x000007fefb160000 - 0x000007fefb178000 C:\Windows\system32\DWMAPI.DLL
0x0000000064910000 - 0x0000000064957000 C:\Program Files\Java\jdk1.8.0_60\jre\bin\fontmanager.dll
0x000007fefdb40000 - 0x000007fefdd17000 C:\Windows\system32\SETUPAPI.dll
0x000007fefd430000 - 0x000007fefd466000 C:\Windows\system32\CFGMGR32.dll
0x000007fefd480000 - 0x000007fefd49a000 C:\Windows\system32\DEVOBJ.dll
0x0000000180000000 - 0x000000018013a000 C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvSCPAPI64.dll
0x0000000065c70000 - 0x0000000065c8a000 C:\Program Files\Java\jdk1.8.0_60\jre\bin\net.dll
0x000007fefc900000 - 0x000007fefc955000 C:\Windows\system32\mswsock.dll
0x000007fefcb50000 - 0x000007fefcb57000 C:\Windows\System32\wship6.dll
0x0000000065c50000 - 0x0000000065c61000 C:\Program Files\Java\jdk1.8.0_60\jre\bin\nio.dll
0x00000000648c0000 - 0x0000000064902000 C:\Program Files\Java\jdk1.8.0_60\jre\bin\t2k.dll
0x000007fef7e80000 - 0x000007fef7f0d000 C:\Users\touch\Desktop\RealSenseSpeech\libpxcclr.jni64.dll
0x000007fef7190000 - 0x000007fef7193000 C:\Windows\system32\api-ms-win-core-synch-l1-2-0.DLL
0x000007fef9c20000 - 0x000007fef9cd8000 C:\Program Files\Common Files\Intel\RSSDK\v6\bin\x64\libpxcsession.dll
0x000007fef7e20000 - 0x000007fef7e72000 C:\Program Files\Common Files\Intel\RSSDK\v6\bin\x64\tbb.dll
0x000007fef3dc0000 - 0x000007fef3e67000 C:\Windows\system32\MSVCP110.dll
0x000007fef3e70000 - 0x000007fef3f44000 C:\Windows\system32\MSVCR110.dll
0x000007fef0700000 - 0x000007fef08e2000 C:\Program Files\Common Files\Intel\RSSDK\v6\bin\x64\libpxccore.dll
0x000007fefcf90000 - 0x000007fefcfb5000 C:\Windows\system32\SspiCli.dll
0x000007fef51e0000 - 0x000007fef52e1000 C:\Program Files\Common Files\Intel\RSSDK\v6\bin\x64\intel-ias2.dll
0x000007fef7dd0000 - 0x000007fef7e1a000 C:\Program Files\Common Files\Intel\RSSDK\v6\bin\x64\libpxclanternrock.dll
0x000007fef50f0000 - 0x000007fef51d4000 C:\Program Files\Common Files\Intel\RSSDK\v6\bin\x64\libpxcpipelineutils.dll
0x000007fef7b10000 - 0x000007fef7b67000 C:\Program Files\Common Files\Intel\RSSDK\v6\bin\x64\libpxcmfaudio.dll
0x000007feec180000 - 0x000007feec571000 C:\Windows\system32\MF.dll
0x000007fefa650000 - 0x000007fefa669000 C:\Windows\system32\ATL.DLL
0x000007fef5020000 - 0x000007fef508d000 C:\Windows\system32\MFPlat.DLL
0x000007fefb060000 - 0x000007fefb069000 C:\Windows\system32\AVRT.dll
0x00000000748a0000 - 0x00000000748a6000 C:\Windows\system32\ksuser.dll
0x000007fef9b50000 - 0x000007fef9b92000 C:\Windows\system32\MFReadWrite.dll
0x000007fefe0d0000 - 0x000007fefe169000 C:\Windows\system32\CLBCatQ.DLL
0x000007fefb2b0000 - 0x000007fefb2fb000 C:\Windows\System32\MMDevApi.dll
0x000007fefb180000 - 0x000007fefb2ac000 C:\Windows\System32\PROPSYS.dll
0x000007fefa4d0000 - 0x000007fefa51f000 C:\Windows\system32\AUDIOSES.DLL
0x000007feef9e0000 - 0x000007feefa63000 C:\Program Files\Common Files\Intel\RSSDK\v6\bin\x64\libpxcvoice_nuance.dll
0x000007fefcb70000 - 0x000007fefcb88000 C:\Windows\system32\CRYPTSP.dll
0x000007fefc650000 - 0x000007fefc697000 C:\Windows\system32\rsaenh.dll
0x000007fefd0d0000 - 0x000007fefd0e4000 C:\Windows\system32\RpcRtRemote.dll
0x000007fefd030000 - 0x000007fefd0c1000 C:\Windows\system32\SXS.DLL
0x000007fefaa20000 - 0x000007fefaa74000 C:\Windows\system32\oleacc.dll
0x0000000064890000 - 0x00000000648ba000 C:\Program Files\Java\jdk1.8.0_60\jre\bin\dcpr.dll
0x000007fef50b0000 - 0x000007fef50eb000 C:\Windows\System32\resampledmo.dll
0x000007feeee40000 - 0x000007feeee4d000 C:\Windows\System32\msdmo.dll
0x000007fefd270000 - 0x000007fefd2ab000 C:\Windows\system32\WINTRUST.dll
0x000007fefd2b0000 - 0x000007fefd41d000 C:\Windows\system32\CRYPT32.dll
0x000007fefd180000 - 0x000007fefd18f000 C:\Windows\system32\MSASN1.dll
0x000007fefbaa0000 - 0x000007fefbbc5000 C:\Windows\system32\dbghelp.dll
VM Arguments:
jvm_args: -Dfile.encoding=UTF-8
java_command: MainFrame
java_class_path (initial): C:\Users\touch\Desktop\RealSenseSpeech\libpxcclr.java.jar;C:\Users\touch\Desktop\RealSenseSpeech\build\classes
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\ProgramData\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\TortoiseSVN\bin;C:\Program Files\ffmpeg\bin;C:\Windows\system32\config\systemprofile\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\
USERNAME=touch
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 26 Stepping 5, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 , 64 bit Build 7601 (6.1.7601.18939)
CPU:total 4 (4 cores per cpu, 2 threads per core) family 6 model 26 stepping 5, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht, tsc, tscinvbit, tscinv
Memory: 4k page, physical 6274276k(3083164k free), swap 12546712k(8511496k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (25.60-b23) for windows-amd64 JRE (1.8.0_60-b27), built on Aug 4 2015 11:06:27 by "java_re" with MS VC++ 10.0 (VS2010)
time: Wed Oct 07 17:38:55 2015
elapsed time: 10 seconds (0d 0h 0m 10s)
Hello Xavier,
I went ahead in the debug and I think I've found the cause.
Once made all substitutions (OnRecognized -> OnRecognition) the JVM crashed during the call to the callback OnRecognition
From my analysis it seems that the problem is the function Marshal :: initialize
When the function analyzes the fields of RecognitionData struct, tries to retrieve fieldID (fid) but the JNI GetFieldID fails when it encounters the field "Results" why can not encode the type ([Lintel/rssdk/PXCMSpeechRecognition$NBest;)
The function returns a FID equals 0 and print
intel/rssdk/PXCMSpeechRecognition$RecognitionData.GetFieldID(results,[Lintel/rssdk/PXCMSpeechRecognition$NBest;) not found
The crash happens during the actual copy Marshal :: why can not retrieve the array without a valid FID
In the Copy_s function of Marshal class at the end there is a switch :
jobject field=jni->GetObjectField(jdata,st->fields.fid); // FID = 0
case 'L':
for (int j=0;j<st->fields.e_num;j++,offset+=st->fields.e_size) {
jobject element=jni->GetObjectArrayElement((jobjectArray)field,j);
Copy_s(jni,st->fields.element,element,offset, csize - st->fields.offset);
the function GetObjectArrayElement crash with field named "Results" (Array of NBest[]) because st->fields.fid = 0 and field object is incorrect
I hope it can be of help my little analysis.
Anyway I will go on with the analysis
Alessio
Hello Xavier, I'm your nightmare :)
I have some good news,
In the previous post I told you that, during initialization of the function copy_s, was not recognized the variable "scores" (NBest [4]) of RecognitionData struct
The reason is that the field names of NBest array differ between the Marshal :: Struct and structure RecognitionData
// Marshal::Field
static Marshal::Field PXCMSpeechRecognition_RecognitionData_fields[]={
{"timeStamp", offsetof(PXCSpeechRecognition::RecognitionData,timeStamp),"J"},
{"grammar", offsetof(PXCSpeechRecognition::RecognitionData,grammar),"I"},
{"duration", offsetof(PXCSpeechRecognition::RecognitionData,duration),"I"},
{"scores", offsetof(PXCSpeechRecognition::RecognitionData, scores), "[Lintel/rssdk/PXCMSpeechRecognition$NBest;", sizeof(PXCSpeechRecognition::NBest), 4, &PXCMSpeechRecognition_NBest},
{0},
// RecognitionData struct
struct RecognitionData {
pxcI64 timeStamp;
pxcUID grammar;
pxcI32 duration;
NBest results[NBEST_SIZE];
pxcI32 reserved[16];
What I did was to realign the names using "scores"
Now I went over,
Now it is properly recognized the array NBest but inside the function copy_s fails to pull the single element from the array NBest
In Marshal.cpp : 155
case '[':
switch (st->fields.sig[1]) {
case 'I':
case 'F':
Copy(jni,offset,st->fields.e_size,st->fields.e_num,(jarray)field);
break;
case 'L':
Copy_s(jni,st->fields.element,offset,element, csize - st->fields.offset);
break;
When he meets the array "scores" the loop executes but GetObjectArrayElement function returns a null value (0x0)
and the recursive call to copy_sfunction is not executed
Do you have any idea ?
Meanwhile, I try to solve it.
Alessio
Thanks Alessio and Xavier!
Initializing the "scores" array with NBest() objects in class intel.rssdk.PXCMSpeechRecognition finally works for me.
public static class RecognitionData {
public long timeStamp; /** The time stamp of the recognition, in 100ns. */
public int grammar; /** The grammar identifier for command and control, or zero for dictation. */
public int duration; /** The duration of the speech, in ms. */
public NBest[] scores; /** @size = NBEST_SIZE; The top-N recognition results for command and control. */
public RecognitionData()
scores = new NBest[NBEST_SIZE];
for(int i=0; i<scores.length; i++){
scores=new NBest();
Best,
Anton
Hi All,
I got this error today and so lucky, I fixed it.
Error: intel/rssdk/PXCMSpeechRecognition$RecognitionData.GetFieldID(results,[Lintel/rssdk/PXCMSpeechRecognition$NBest;) not found
SDK: Build Number: 10.0.26.0396 (1.8GB)
Version: 2016 R2
Solution:
PXCMSpeechRecognition.java, change this
to this:
scores=new NBest();
from
{"results", offsetof(PXCSpeechRecognition::RecognitionData, scores), "[Lintel/rssdk/PXCMSpeechRecognition$NBest;", sizeof(PXCSpeechRecognition::NBest), 4, &PXCMSpeechRecognition_NBest},
{0},
to
{0},
Thanks you,
Dat Nguyen.
