Software Archive
Read-only legacy content
Java script and AJAX working in Emulator but not on my device
Adil_K_
Could someone please help me, I tried to create a simple application that can view information from a database. It is working in the emulation mode, but when I try the application on my device it does not work. I am new to Intel XDK, any help will be greatly appreciated.
Diego_Calp
Valued Contributor I
Hi Adil,
I think that the problem is that in your device this won't work:
http://localhost/Hospital/GetPatientData.php
This url should be the server's one.
Diego
PaulF_IntelCorp
It's probably related to the whitelist settings on the Projects tab, but it's hard to say precisely. Did you try some of the demo/sample apps to see how they are configured? Especially the whitelist settings.
Also, try using the Debug tab, it will provide a more accurate view of running your app on a real system. See this doc for even more options > https://software.intel.com/en-us/xdk/docs/intel-xdk-debug-and-test-overview
Adil_K_
Thanks Paul for the response.
I have tried the whitelist settings. I will upload some pictures of what I have done, so that the problem can be a bit more clear.
Diego_Calp
Hi Adil,
Diego
PaulF_IntelCorp
Hi Adil, Deigo's comment is the most likely cause of your troubles. Also, see this blog for some useful getting started hints regarding how a Cordova app differs from a web app > http://blogs.intel.com/evangelists/2015/12/31/five-useful-tips-on-getting-started-building-cordova-mobile-apps-with-the-intel-xdk/
Adil_K_
Thank you Diego and Paul, I have resolved my problem. I had to remove the hidden frame part, change the whitelist settings, and change the local host to my IP address in the html portion of the code.
