Software Archive
Read-only legacy content
17060 Discussions
LB_RESETCONTENT
jameshprice
I am trying to use an LB_RESETCONTENT message to clear a ListBox in a QuickWin program. This call is not clearing the box. Should I use something else? I did a test using LB_GETCOUNT and it worked.
Jugoslav_Dujic
Valued Contributor II
If you're using DFLOGM, it keeps buffered number and contents of items. My guess is that DFLOGM puts that info back into the listbox soon after you empty it (i.e. LB_RESETCONTENT works but you don't see it). Preferred way is to use DlgSet(Dlg, IDC_LIST1, 0, DLG_NUMITEMS).
jameshprice
I used the DLG_NUMITEMS in DlgSet and it did clear the ListBox. Thanks . Also, I was using DFLOGM so you were correct on all accounts.
