Software Archive
Read-only legacy content
17060 Discussions
LBR and Virtualization
Yoav_A_
I'm using LBR to trace guest execution, each time before vm_enter I overwrite the MSR_LASTBRANCH_(N-1)_FROM_IP/TO values with a magic value (0xdeadbabe) and execute a few instructions and read out the values. sometimes a record is skipped in the LBR and contains the magic value.
why would this ever happen? I've look at the errata for haswell and didn't see anything similar, and running a similar code on the host outputs a perfect sequential trace. could this be an hardware bug related to vmx?
Yoav
Quoc-Thai_L_Intel
You might want to check with open-source community to see how they would handle the issue that you are having.
Here are some examples of Virtualization code:
-Thai
