I am attempting to use LIBXSMM on a Xeon Phi and it fails to compile when I use
make install OFFLOAD=1 PREFETCH=1 MNK="2,4,6,8,10,12,14,16,18,20,23"
I am getting the error
~/libxsmm/samples/smm/specialized.cpp(143): error: call of an object of a class type without appropriate operator() or conversion functions to pointer-to-function type
xmm(pa, pb, pc LIBXSMM_PREFETCH_ARGA(pa + asize) LIBXSMM_PREFETCH_ARGB(pb + bsize) LIBXSMM_PREFETCH_ARGC(tmp) LIBXSMM_PREFETCH_ARGC(pc + csize_act));
It will compile on the Phi without prefetching, and it will compile with prefetching when not being offloaded to the Phi. Is there something I need to add for prefetching on the Phi?
I am checked out at commit 00dd1455655fe2a715ae8b0f90d38fbb3680f48a, because it will not compile for the Phi at all on the most recent release.
The issue is fixed and can be found under https://github.com/hfp/libxsmm/issues/28 for further reference.
