Software Archive
Read-only legacy content
17060 Discussions
Laser power issue
Ncare
Hi, I built a test function which changed the laser power settings on the IR cam (SetIVCAMLaserPower). I then unplugged the RealSense without changing the laser power setting back to default. When I use the depth sensor today, the laser power seems 'scaled' to my last setting - even with power at 16 I can't get any depth reading more than 50cm away.
Changing the laser power does scale the depth distance available, but only within this new, smaller range. When I look at the IR stream, the intensity even for close objects seems very low compared to previously, consistent with a lower power setting.
Any ideas for a quick fix? Or a slow fix, even.
