I filled every fields. there are no orange exclamation icon... but the list is still locked.. someone knows why?
- Tags:
- HTML5
- Intel® XDK
Marcos -- are you referring to problems with the publish tab? Please clarify.
Yes Paul. is it!
In each tab inside it (store information, Description, Graphic Assets and packages) every mandatory field are ok and there are no alarms.. and i had built my project and ìm importing it in Apk format...
Marcos -- nothing obvious based on the information you've provided. Could you ZIP your ENTIRE project and send it to me via private message? I'll send you a private message, as well. --Paul
So, did you guys had any success with this case? I'm facing the same issue.
Could you shed some more light about what happened after you checked the zipped project?
Thanks in advance
Logixor -- no further information was provided by Marcos, there is no further resolution of the problem.
Should I open a new topic then?
No need to open a new topic, we simply did not get any detailed info from Marcos that allowed us to further debug the issue. If you're able to provide more details it might help resolve or understand the issue. For example, some screenshots highlighting the specific issue and/or a ZIP of your project folder would help.
Ok, I will prepare a ZIP. just for information, where do I upload the ZIP, or I need to send it to you?
Hi friends!I'm so sorry for don't let any news here about it.
But I gave up to try lunch my app by there. Then, I don't know how to fix it.
![](/skins/images/06022F5BB6D2F28C8F102671A0F06E85/responsive_peak/images/icon_anonymous_message.png)
