Software Archive
Read-only legacy content
MCV change
mauricio_p_
Hi!!
I searched in form but i did not find any topic about it.
how can i change the MCV for a service?
Amrita_C_Intel
What is MCV? Can you please provide some more details.
Chris_P_Intel
Mauricio,
Do you mean that you were using the Design view and you initially selected Angular (for example) and now want to switch to Backbone? (or the reverse)
That will not be an easy switch. From the HTML code of your file you will have to remove the inclusions of Angular, the other service supporting files, as well as any service related markup that may have been added (ng-app, ng-repeat, ng-controller). If done correctly, then you can open the file back in Deign view and re-apply the service and choose the other MVC framework.
Chris
mauricio_p_
Hi Guys,
Sorry Amrita, i mistyped is MVC and the question was malformed, but Chris understood what I needed.
The tool is great, but the service creation using JSON took me long hours to understand how to connect things!
Mauricio
