Software Archive
Read-only legacy content
MPSS start failed
Weigong_G_
I install MPSS v3.3 on CentOS v6.5 64-bit workstation. When I "did sudo micctrl --initdefaults", there is a warning: "No Mic cards found or specified on command line", and "sudo service mpss start", it show "Starting Intel (R) MPSS: [FAILED]". I also found there missing "/etc/mpss/mic*.conf".
Does someone please help me fix my problem?
Sunny_G_Intel
Hi Weigong,
We had a similar thread related to MPSS 3.3 and Centos 6.5. Can you please refer to this link.
you might try the following steps to assure the current modules are installed correctly (assuming default kernel version *431 for Centos 6.5):
rmmod mic
micctrl --cleanconfig
mpss-3.3/uninstall.sh
reboot
yum install mpss-3.3/*.rpm
yum install mpss-3.3/modules/*431*.rpm
modprobe mic
service mpss start
micctrl -s
Weigong_G_
Hello Sunny,
Thank you for your help.
I follow your instructions to reinstall the MPSS. It has same problem below:
[Warning] No Mic cards found or specified on command line
Starting Intel(R) MPSS:                                    [FAILED]
Sunny_G_Intel
Hi Weigong,
Before going further let us confirm that the coprocessor is enumerated correctly by the host.
Can you please verify the output of the following command:
lspci | grep -i "coprocessor"
We will also verify that after running
your mic.ko file was installed in the correct kernel folder by executing the following commands:
uname -r
find /lib/modules/ -name mic.ko
Can you please share the output for the above commands
Weigong_G_
Hi Sunny,
There are the output:
ad_fsc_wge@ncu0124366 ~]$ lspci | grep -i "coprocessor"
[ad_fsc_wge@ncu0124366 ~]$ sudo lspci | grep -i "coprocessor"
[sudo] password for ad_fsc_wge:
[ad_fsc_wge@ncu0124366 ~]$ micctrl --initdefaults
  [Error] Only root is allowed to use this option
[ad_fsc_wge@ncu0124366 ~]$ sudo micctrl --initdefaults
[ad_fsc_wge@ncu0124366 ~]$ uname -r
2.6.32-431.23.3.el6.x86_64
[ad_fsc_wge@ncu0124366 ~]$ find /lib/modules/ -name mic.ko
/lib/modules/3.0.13-0.27-default/extra/mic.ko
/lib/modules/2.6.32-220.el6.x86_64/extra/mic.ko
/lib/modules/2.6.32-279.el6.x86_64/extra/mic.ko
/lib/modules/3.10.0-123.el7.x86_64/extra/mic.ko
/lib/modules/2.6.32-431.el6.x86_64/extra/mic.ko
/lib/modules/3.0.76-0.11-default/extra/mic.ko
/lib/modules/2.6.32-358.el6.x86_64/extra/mic.ko
/lib/modules/2.6.32-431.23.3.el6.x86_64/extra/mic.ko
Sunny_G_Intel
Hi Weigong,
Can you please paste the output for:
 lspci | grep -i co-processor
I apologize for missing the dash in reply earlier.
Weigong_G_
Hi Sunny,
This command does not has output.
Sunny_G_Intel
Hi Weigong,
Thank you for running the commands for me. When I look at the outputs you posted I feel there may be a chance that your installed coprocessors are not seen by your host system. I would like to redirect you to the following post from my colleague addressing a similar issue.
Loc_N_Intel
Hi Weigong,
Please try "lspci | grep Co-processor" instead, not "lspci | grep co-processor"
Weigong_G_
Thank you for your help. I am very confused about the coprocessor. I install the NVIDIA GeForce GTX TINTAN BLACK on the computer. We have some a job running on it (one job/time). I just got the result on below. Do you think I have reinstall this card or move it to another slot?
[ad_fsc_wge@ncu0124366 ~]$ nvidia-smi
Thu Aug 28 15:54:12 2014
| NVIDIA-SMI 340.24     Driver Version: 340.24         |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX TIT...  Off  | 0000:03:00.0     N/A |                  N/A |
| 55%   82C    P2    N/A /  N/A |    740MiB /  6143MiB |     N/A   E. Process |
| Compute processes:                                               GPU Memory |
|  GPU       PID  Process name                                     Usage      |
|    0            Not Supported                                               |
Weigong_G_
The"lspci | grep Co-processor” also does not has any output.
Sunny_G_Intel
Hi Weigong,
Yes we can try switching the slots to confirm that the card is inserted properly and all power connectors on the card are plugged in correctly. Also, as my colleague suggested in this post we need to make sure that the coprocessor is installed on an enabled PCI slot and it is getting adequate power.
Weigong_G_
Hi Sunny,
I will be going to switch the slot PCI of my video card. Below are output of my PCI reports:
[ad_fsc_wge@ncu0124366 ~]$ lspci
00:00.0 Host bridge: Intel Corporation 5520 I/O Hub to ESI Port (rev 22)
00:01.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 1 (rev 22)
00:03.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 3 (rev 22)
00:07.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 7 (rev 22)
00:14.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub System Management Registers (rev 22)
00:14.1 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers (rev 22)
00:14.2 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers (rev 22)
00:1a.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4
00:1a.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5
00:1a.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6
00:1a.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2
00:1b.0 Audio device: Intel Corporation 82801JI (ICH10 Family) HD Audio Controller
00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1
00:1c.5 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 6
00:1d.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1
00:1d.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2
00:1d.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3
00:1d.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90)
00:1f.0 ISA bridge: Intel Corporation 82801JIR (ICH10R) LPC Interface Controller
00:1f.2 SATA controller: Intel Corporation 82801JI (ICH10 Family) SATA AHCI Controller
00:1f.3 SMBus: Intel Corporation 82801JI (ICH10 Family) SMBus Controller
01:00.0 PCI bridge: Pericom Semiconductor PCI Express to PCI-XPI7C9X130 PCI-X Bridge (rev 04)
03:00.0 VGA compatible controller: NVIDIA Corporation Device 100c (rev a1)
03:00.1 Audio device: NVIDIA Corporation GK110 HDMI Audio (rev a1)
05:00.0 SCSI storage controller: LSI Logic / Symbios Logic SAS1068E PCI-Express Fusion-MPT SAS (rev 08)
06:00.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5761 Gigabit Ethernet PCIe (rev 10)
07:0a.0 FireWire (IEEE 1394): Texas Instruments TSB43AB22A IEEE-1394a-2000 Controller (PHY/Link) [iOHCI-Lynx]
20:03.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 3 (rev 22)
20:07.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 7 (rev 22)
20:09.0 PCI bridge: Intel Corporation 7500/5520/5500/X58 I/O Hub PCI Express Root Port 9 (rev 22)
20:14.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub System Management Registers (rev 22)
20:14.1 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers (rev 22)
[ad_fsc_wge@ncu0124366 ~]$ lspci | grep Corporation
20:14.2 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers (rev 22)
Weigong_G_
Hi Sunny,
I double check the video card connection. It looks fine. I got another report on below. Thanks.
[ad_fsc_wge@ncu0124366 ~]$ lspci -v
        Subsystem: Dell Device 026d
        Flags: fast devsel, IRQ 11
        Capabilities: <access denied>
00:01.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 1 (rev 22) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0
        Bus: primary=00, secondary=01, subordinate=02, sec-latency=0
        Memory behind bridge: f5e00000-f5efffff
        Kernel modules: shpchp
00:03.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 3 (rev 22) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
        I/O behind bridge: 0000d000-0000dfff
        Memory behind bridge: f6000000-f7efffff
        Prefetchable memory behind bridge: 00000000e8000000-00000000f1ffffff
00:07.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 7 (rev 22) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
        Memory behind bridge: f5f00000-f5ffffff
00:14.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub System Management Registers (rev 22) (prog-if 00 [8259])
        Subsystem: Device 0028:006d
        Flags: fast devsel
        Kernel modules: i7core_edac
00:14.1 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers (rev 22) (prog-if 00 [8259])
        Flags: fast devsel
00:14.2 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers (rev 22) (prog-if 00 [8259])
        Flags: fast devsel
00:1a.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4 (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 16
        I/O ports at 1f20 [size=32]
        Kernel driver in use: uhci_hcd
00:1a.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5 (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 17
        I/O ports at 1f00 [size=32]
00:1a.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6 (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 22
        I/O ports at 1c00 [size=32]
00:1a.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2 (prog-if 20 [EHCI])
        Memory at f7ffa000 (32-bit, non-prefetchable) [size=1K]
        Kernel driver in use: ehci_hcd
        Flags: bus master, fast devsel, latency 0, IRQ 75
        Memory at f7ffc000 (64-bit, non-prefetchable) [size=16K]
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd-hda-intel
00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1 (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
        I/O behind bridge: 0000c000-0000cfff
        Memory behind bridge: f5c00000-f5dfffff
        Prefetchable memory behind bridge: 00000000f2300000-00000000f24fffff
        Kernel driver in use: pcieport
00:1c.5 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 6 (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
        I/O behind bridge: 00002000-00002fff
        Memory behind bridge: f5b00000-f5bfffff
        Prefetchable memory behind bridge: 00000000f2100000-00000000f22fffff
00:1d.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1 (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 23
        I/O ports at 1f80 [size=32]
00:1d.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2 (prog-if 00 [UHCI])
        I/O ports at 1f60 [size=32]
00:1d.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3 (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 18
        I/O ports at 1f40 [size=32]
00:1d.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1 (prog-if 20 [EHCI])
        Memory at ff980000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90) (prog-if 01 [Subtractive decode])
        Bus: primary=00, secondary=07, subordinate=07, sec-latency=32
        Memory behind bridge: f5a00000-f5afffff
        Kernel driver in use: lpc_ich
        Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 82801JI (ICH10 Family) SATA AHCI Controller (prog-if 01 [AHCI 1.0])
        Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 74
        I/O ports at 1e00 [size=8]
        I/O ports at 1e10 [size=4]
        I/O ports at 1e20 [size=8]
        I/O ports at 1e30 [size=4]
        I/O ports at 1ec0 [size=32]
        Memory at f2000000 (32-bit, non-prefetchable) [size=2K]
        Kernel driver in use: ahci
        Kernel modules: ahci
        Flags: medium devsel, IRQ 20
        Memory at f7ffb000 (64-bit, non-prefetchable) [size=256]
        I/O ports at ece0 [size=32]
        Kernel driver in use: i801_smbus
        Kernel modules: i2c-i801
01:00.0 PCI bridge: Pericom Semiconductor PCI Express to PCI-XPI7C9X130 PCI-X Bridge (rev 04) (prog-if 00 [Normal decode])
        Bus: primary=01, secondary=02, subordinate=02, sec-latency=64
03:00.0 VGA compatible controller: NVIDIA Corporation Device 100c (rev a1) (prog-if 00 [VGA controller])
        Subsystem: eVga.com. Corp. Device 3791
        Flags: bus master, fast devsel, latency 0, IRQ 77
        Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
        Memory at e8000000 (64-bit, prefetchable) [size=128M]
        Memory at f0000000 (64-bit, prefetchable) [size=32M]
        I/O ports at dc80 [size=128]
        [virtual] Expansion ROM at f7e00000 [disabled] [size=512K]
        Kernel driver in use: nvidia
        Kernel modules: nvidia, nouveau, nvidiafb
        Flags: bus master, fast devsel, latency 0, IRQ 34
        Memory at f7dfc000 (32-bit, non-prefetchable) [size=16K]
        Subsystem: Dell SAS 6/iR Integrated Workstations RAID Controller
        Flags: bus master, fast devsel, latency 0, IRQ 16
        I/O ports at cc00 [size=256]
        Memory at f5cec000 (64-bit, non-prefetchable) [size=16K]
        Memory at f5cf0000 (64-bit, non-prefetchable) [size=64K]
        Expansion ROM at f5d00000 [disabled] [size=1M]
        Kernel driver in use: mptsas
        Kernel modules: mptsas
        Flags: bus master, fast devsel, latency 0, IRQ 76
        Memory at f5be0000 (64-bit, non-prefetchable) [size=64K]
        Memory at f5bf0000 (64-bit, non-prefetchable) [size=64K]
        Kernel driver in use: tg3
        Kernel modules: tg3
07:0a.0 FireWire (IEEE 1394): Texas Instruments TSB43AB22A IEEE-1394a-2000 Controller (PHY/Link) [iOHCI-Lynx] (prog-if 10 [OHCI])
        Flags: bus master, medium devsel, latency 64, IRQ 18
        Memory at f5afb000 (32-bit, non-prefetchable) [size=2K]
        Memory at f5afc000 (32-bit, non-prefetchable) [size=16K]
        Kernel driver in use: firewire_ohci
        Kernel modules: firewire-ohci
20:03.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 3 (rev 22) (prog-if 00 [Normal decode])
        Bus: primary=20, secondary=22, subordinate=22, sec-latency=0
        Memory behind bridge: e7f00000-e7ffffff
20:07.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 7 (rev 22) (prog-if 00 [Normal decode])
        Bus: primary=20, secondary=23, subordinate=23, sec-latency=0
        Memory behind bridge: e7e00000-e7efffff
20:09.0 PCI bridge: Intel Corporation 7500/5520/5500/X58 I/O Hub PCI Express Root Port 9 (rev 22) (prog-if 00 [Normal decode])
        Bus: primary=20, secondary=24, subordinate=24, sec-latency=0
        Memory behind bridge: e7d00000-e7dfffff
20:14.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub System Management Registers (rev 22) (prog-if 00 [8259])
        Flags: fast devsel
20:14.1 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers (rev 22) (prog-if 00 [8259])
        Flags: fast devsel
20:14.2 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers (rev 22) (prog-if 00 [8259])
        Flags: fast devsel
Sunny_G_Intel
Hi Weigong,
After closely observing the output of
lspci -v
it looks like the system is not able to detect the card and/or the PCIe link training was not completed successfully. Can you please confirm the output for the following commands/steps:
Step 1:
 dmesg | less
and search for "mic " . (by pressing "/mic "  -- note the space after mic)
In case you see a failing message for mic,  we need to confirm that "In your host BIOS, support for mapping > 4GB MMIO" is enabled.
Step 2:
After executing the following command
lspci -vvv | less
search for "Co-processor" (by pressing "/Co-processor"). Once you find the entry for Co-processor search for corresponding LnkSta. The values we are interested here are "Speed" and "Width".
A good hardware troubleshooting flowchart to follow is this one
Weigong_G_
Hi Sunny,
There are results I got on below. Both of search of "/mic" and "/Co-processor" I got same result: "No such file or directory". The host computer still running some jobs. Once it jobs done, I will be confirm the support for mapping > 4GB MMIO is enabled or no.
Weigong
[ad_fsc_wge@ncu0124366 ~]$ dmesg | less
Initializing cgroup subsys cpuset
Linux version 2.6.32-431.23.3.el6.x86_64 (mockbuild@c6b8.bsys.dev.centos.org) (gcc version 4.4.7 20120313 (Red Hat 4.4.7-4) (GCC) ) #1 SMP Thu Jul 31 17:20:51 UTC 2014
Command line: ro root=/dev/mapper/vg_ncu0124366-LogVol01 rd_NO_LUKS rd_LVM_LV=vg_ncu0124366/LogVol00 rd_LVM_LV=vg_ncu0124366/LogVol01 rd_NO_MD SYSFONT=latarcyrheb-sun16 crashkernel=128M  KEYBOARDTYPE=pc KEYTABLE=us rd_NO_DM LANG=en_US.UTF-8 rhgb quiet rdblacklist=nouveau
KERNEL supported cpus:
  Intel GenuineIntel
  AMD AuthenticAMD
  Centaur CentaurHauls
BIOS-provided physical RAM map:
 BIOS-e820: 0000000000000000 - 000000000009dc00 (usable)
 BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
 BIOS-e820: 0000000000100000 - 00000000d7df9c00 (usable)
 BIOS-e820: 00000000d7df9c00 - 00000000d7e4bc00 (ACPI NVS)
 BIOS-e820: 00000000d7e4bc00 - 00000000d7e4dc00 (ACPI data)
 BIOS-e820: 00000000d7e4dc00 - 00000000d8000000 (reserved)
 BIOS-e820: 00000000f8000000 - 00000000fd000000 (reserved)
 BIOS-e820: 00000000fe000000 - 00000000fed00400 (reserved)
 BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
 BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
 BIOS-e820: 0000000100000000 - 0000000628000000 (usable)
DMI 2.5 present.
SMBIOS version 2.5 @ 0xF0430
DMI: Dell Inc. Precision WorkStation T7500  /06FW8P, BIOS A12 10/30/2011
e820 update range: 0000000000000000 - 0000000000001000 (usable) ==> (reserved)
e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
last_pfn = 0x628000 max_arch_pfn = 0x400000000
MTRR default type: write-back
MTRR fixed ranges enabled:
  00000-9FFFF write-back
  A0000-BFFFF uncachable
  C0000-DBFFF write-protect
  DC000-EFFFF uncachable
  F0000-FFFFF write-protect
MTRR variable ranges enabled:
  0 base 00D7F00000 mask FFFFF00000 uncachable
  1 base 00D8000000 mask FFF8000000 uncachable
  2 base 00E0000000 mask FFE0000000 uncachable
  3 disabled
  4 disabled
  5 disabled
  6 disabled
  7 disabled
  8 disabled
  9 disabled
x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
last_pfn = 0xd7df9 max_arch_pfn = 0x400000000
initial memory mapped : 0 - 20000000
Using GB pages for direct mapping
init_memory_mapping: 0000000000000000-00000000d7df9000
 0000000000 - 00c0000000 page 1G
 00c0000000 - 00d7c00000 page 2M
 00d7c00000 - 00d7df9000 page 4k
kernel direct mapping tables up to d7df9000 @ 8000-b000
Use unified mapping for non-reserved e820 regions.
init_memory_mapping: 0000000100000000-0000000628000000
 0100000000 - 0600000000 page 1G
 0600000000 - 0628000000 page 2M
kernel direct mapping tables up to 628000000 @ a000-c000
RAMDISK: 36f36000 - 37fef15a
ACPI: RSDP 00000000000fec30 00024 (v02 DELL  )
ACPI: XSDT 00000000000fcaf5 00084 (v01 DELL    B10K    00000015 ASL  00000061)
ACPI: FACP 00000000000fcbed 000F4 (v03 DELL    B10K    00000015 ASL  00000061)
ACPI: DSDT 00000000ffea1b5a 05908 (v01   DELL    dt_ex 00001000 INTL 20050624)
ACPI: FACS 00000000d7df9c00 00040
ACPI: SSDT 00000000ffea7573 0009C (v01   DELL    st_ex 00001000 INTL 20050624)
ACPI: APIC 00000000000fcce1 0026A (v01 DELL    B10K    00000015 ASL  00000061)
ACPI: BOOT 00000000000fcf4b 00028 (v01 DELL    B10K    00000015 ASL  00000061)
ACPI: ASF! 00000000000fcf73 00096 (v32 DELL    B10K    00000015 ASL  00000061)
ACPI: MCFG 00000000000fd009 0003C (v01 DELL    B10K    00000015 ASL  00000061)
ACPI: HPET 00000000000fd045 00038 (v01 DELL    B10K    00000015 ASL  00000061)
ACPI: TCPA 00000000000fd2a1 00032 (v01 DELL    B10K    00000015 ASL  00000061)
ACPI: ____ 00000000000fd2d3 00030 (v01 DELL    B10K    00000015 ASL  00000061)
ACPI: _RAT 00000000000fded5 00030 (v01 DELL    B10K    00000015 ASL  00000061)
ACPI: SLIC 00000000000fd07d 00176 (v01 DELL    B10K    00000015 ASL  00000061)
ACPI: SSDT 00000000d7e4dc00 015C4 (v01  INTEL PPM RCM  80000001 INTL 20061109)
ACPI: Local APIC address 0xfee00000
Setting APIC routing to flat.
No NUMA configuration found
Faking a node at 0000000000000000-0000000628000000
Bootmem setup node 0 0000000000000000-0000000628000000
  NODE_DATA [000000000000b000 - 000000000003efff]
  bootmap [0000000000100000 -  00000000001c4fff] pages c5
(8 early reservations) ==> bootmem [0000000000 - 0628000000]
  #0 [0000000000 - 0000001000]   BIOS data page ==> [0000000000 - 0000001000]
  #1 [0000006000 - 0000008000]       TRAMPOLINE ==> [0000006000 - 0000008000]
  #2 [0001000000 - 0002020aa4]    TEXT DATA BSS ==> [0001000000 - 0002020aa4]
  #3 [0036f36000 - 0037fef15a]          RAMDISK ==> [0036f36000 - 0037fef15a]
  #4 [000009dc00 - 0000100000]    BIOS reserved ==> [000009dc00 - 0000100000]
  #5 [0002021000 - 0002021214]              BRK ==> [0002021000 - 0002021214]
  #6 [0000008000 - 000000a000]          PGTABLE ==> [0000008000 - 000000a000]
  #7 [000000a000 - 000000b000]          PGTABLE ==> [000000a000 - 000000b000]
Reserving 128MB of memory at 48MB for crashkernel (System RAM: 25216MB)
 [ffffea0000000000-ffffea000effffff] PMD -> [ffff880028600000-ffff880036dfffff] on node 0
 [ffffea000f000000-ffffea00159fffff] PMD -> [ffff880038000000-ffff88003e9fffff] on node 0
Zone PFN ranges:
  DMA      0x00000001 -> 0x00001000
  DMA32    0x00001000 -> 0x00100000
  Normal   0x00100000 -> 0x00628000
Movable zone start PFN for each node
early_node_map[3] active PFN ranges
    0: 0x00000001 -> 0x0000009d
    0: 0x00000100 -> 0x000d7df9
    0: 0x00100000 -> 0x00628000
On node 0 totalpages: 6290837
  DMA zone: 56 pages used for memmap
  DMA zone: 104 pages reserved
  DMA zone: 3836 pages, LIFO batch:0
  DMA32 zone: 14280 pages used for memmap
  DMA32 zone: 865841 pages, LIFO batch:31
  Normal zone: 73920 pages used for memmap
  Normal zone: 5332800 pages, LIFO batch:31
ACPI: PM-Timer IO Port: 0x808
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x20] enabled)
ACPI: LAPIC (acpi_id[0x02] lapic_id[0x22] enabled)
ACPI: LAPIC (acpi_id[0x03] lapic_id[0x32] enabled)
ACPI: LAPIC (acpi_id[0x04] lapic_id[0x34] enabled)
ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] enabled)
ACPI: LAPIC (acpi_id[0x06] lapic_id[0x02] enabled)
ACPI: LAPIC (acpi_id[0x07] lapic_id[0x12] enabled)
ACPI: LAPIC (acpi_id[0x08] lapic_id[0x14] enabled)
ACPI: LAPIC (acpi_id[0x09] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x0a] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x0b] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x0c] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x0d] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x0e] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x0f] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x10] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x11] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x12] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x13] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x14] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x15] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x16] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x17] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x18] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x19] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x1a] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x1b] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x1c] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x1d] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x1e] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x1f] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x20] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x21] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x22] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x23] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x24] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x25] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x26] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x27] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x28] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x29] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x2a] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x2b] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x2c] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x2d] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x2e] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x2f] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x30] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x31] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x32] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x33] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x34] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x35] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x36] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x37] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x38] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x39] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x3a] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x3b] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x3c] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x3d] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x3e] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x3f] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x40] lapic_id[0x00] disabled)
ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
ACPI: IOAPIC (id[0x09] address[0xfec80000] gsi_base[24])
IOAPIC[1]: apic_id 9, version 32, address 0xfec80000, GSI 24-47
ACPI: IOAPIC (id[0x0a] address[0xfec88000] gsi_base[48])
IOAPIC[2]: apic_id 10, version 32, address 0xfec88000, GSI 48-71
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Using ACPI (MADT) for SMP configuration information
ACPI: HPET id: 0x8086a301 base: 0xfed00000
SMP: Allowing 64 CPUs, 56 hotplug CPUs
nr_irqs_gsi: 72
PM: Registered nosave memory: 000000000009d000 - 00000000000f0000
PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
PM: Registered nosave memory: 00000000d7df9000 - 00000000d7dfa000
PM: Registered nosave memory: 00000000d7dfa000 - 00000000d7e4b000
PM: Registered nosave memory: 00000000d7e4b000 - 00000000d7e4c000
PM: Registered nosave memory: 00000000d7e4c000 - 00000000d7e4d000
PM: Registered nosave memory: 00000000d7e4d000 - 00000000d7e4e000
PM: Registered nosave memory: 00000000d7e4e000 - 00000000d8000000
PM: Registered nosave memory: 00000000d8000000 - 00000000f8000000
PM: Registered nosave memory: 00000000f8000000 - 00000000fd000000
PM: Registered nosave memory: 00000000fd000000 - 00000000fe000000
PM: Registered nosave memory: 00000000fe000000 - 00000000fed00000
PM: Registered nosave memory: 00000000fed00000 - 00000000fee00000
PM: Registered nosave memory: 00000000fee00000 - 00000000fef00000
PM: Registered nosave memory: 00000000fef00000 - 00000000ffb00000
PM: Registered nosave memory: 00000000ffb00000 - 0000000100000000
Allocating PCI resources starting at d8000000 (gap: d8000000:20000000)
Booting paravirtualized kernel on bare hardware
NR_CPUS:4096 nr_cpumask_bits:64 nr_cpu_ids:64 nr_node_ids:1
PERCPU: Embedded 31 pages/cpu @ffff88003ea00000 s94872 r8192 d23912 u131072
pcpu-alloc: s94872 r8192 d23912 u131072 alloc=1*2097152
pcpu-alloc: [0] 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15
pcpu-alloc: [0] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
pcpu-alloc: [0] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
pcpu-alloc: [0] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 6202477
Policy zone: Normal
Kernel command line: ro root=/dev/mapper/vg_ncu0124366-LogVol01 rd_NO_LUKS rd_LVM_LV=vg_ncu0124366/LogVol00 rd_LVM_LV=vg_ncu0124366/LogVol01 rd_NO_MD SYSFONT=latarcyrheb-sun16 crashkernel=128M  KEYBOARDTYPE=pc KEYTABLE=us rd_NO_DM LANG=en_US.UTF-8 rhgb quiet rdblacklist=nouveau
PID hash table entries: 4096 (order: 3, 32768 bytes)
Checking aperture...
No AGP bridge found
PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Placing 64MB software IO TLB between ffff880020000000 - ffff880024000000
software IO TLB at phys 0x20000000 - 0x24000000
Memory: 24577988k/25821184k available (5330k kernel code, 657836k absent, 585360k reserved, 7009k data, 1280k init)
Hierarchical RCU implementation.
NR_IRQS:33024 nr_irqs:1736
Console: colour VGA+ 80x25
console [tty0] enabled
allocated 100663296 bytes of page_cgroup
please try 'cgroup_disable=memory' option if you don't want memory cgroups
hpet clockevent registered
Fast TSC calibration using PIT
Detected 3591.282 MHz processor.
Calibrating delay loop (skipped), value calculated using timer frequency.. 7182.56 BogoMIPS (lpj=3591282)
pid_max: default: 65536 minimum: 512
Security Framework initialized
SELinux:  Initializing.
SELinux:  Starting in permissive mode
Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
Mount-cache hash table entries: 256
Initializing cgroup subsys ns
Initializing cgroup subsys cpuacct
Initializing cgroup subsys memory
Initializing cgroup subsys devices
Initializing cgroup subsys freezer
Initializing cgroup subsys net_cls
Initializing cgroup subsys blkio
Initializing cgroup subsys perf_event
Initializing cgroup subsys net_prio
CPU: Physical Processor ID: 1
CPU: Processor Core ID: 0
mce: CPU supports 9 MCE banks
CPU0: Thermal monitoring enabled (TM1)
using mwait in idle threads.
ACPI: Core revision 20090903
ftrace: converting mcount calls to 0f 1f 44 00 00
ftrace: allocating 21786 entries in 86 pages
APIC routing finalized to physical flat.
..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
CPU0: Intel(R) Xeon(R) CPU           X5687  @ 3.60GHz stepping 02
Performance Events: PEBS fmt1+, 16-deep LBR, Westmere events, Intel PMU driver.
CPUID marked event: 'bus cycles' unavailable
... version:                3
... bit width:              48
... generic registers:      4
... value mask:             0000ffffffffffff
... max period:             000000007fffffff
... fixed-purpose events:   3
... event mask:             000000070000000f
NMI watchdog enabled, takes one hw-pmu counter.
Booting Node   0, Processors  #1 #2 #3 #4 #5 #6 #7
Brought up 8 CPUs
Total of 8 processors activated (57457.02 BogoMIPS).
sizeof(vma)=200 bytes
sizeof(page)=56 bytes
sizeof(inode)=592 bytes
sizeof(dentry)=192 bytes
sizeof(ext3inode)=800 bytes
sizeof(buffer_head)=104 bytes
sizeof(skbuff)=232 bytes
sizeof(task_struct)=2648 bytes
devtmpfs: initialized
PM: Registering ACPI NVS region at d7df9c00 (335872 bytes)
regulator: core version 0.5
NET: Registered protocol family 16
ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
ACPI: bus type pci registered
PCI: MCFG configuration 0: base f8000000 segment 0 buses 0 - 63
PCI: MCFG area at f8000000 reserved in E820
PCI: Using MMCONFIG at f8000000 - fbffffff
PCI: Using configuration type 1 for base access
dmi type 0xB1 record - unknown flag
bio: create slab <bio-0> at 0
ACPI: EC: Look up EC in DSDT
ACPI: BIOS _OSI(Linux) query ignored
ACPI: Interpreter enabled
ACPI: (supports S0 S3 S4 S5)
ACPI: Using IOAPIC for interrupt routing
ACPI: No dock devices found.
PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7f])
pci_root PNP0A03:00: host bridge window [io  0x0000-0x03af]
pci_root PNP0A03:00: host bridge window [io  0x03b0-0x03bb]
pci_root PNP0A03:00: host bridge window [io  0x03bc-0x03bf]
pci_root PNP0A03:00: host bridge window [io  0x03c0-0x03df]
pci_root PNP0A03:00: host bridge window [io  0x03e0-0x0cf7]
pci_root PNP0A03:00: host bridge window [io  0x0d00-0xefff]
pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff]
pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000effff]
pci_root PNP0A03:00: host bridge window [mem 0x000f0000-0x000fffff]
pci_root PNP0A03:00: host bridge window [mem 0xe8000000-0xf7ffffff]
pci_root PNP0A03:00: host bridge window [mem 0xd7f00000-0xe6ffffff]
pci_root PNP0A03:00: host bridge window [mem 0xff980000-0xff980fff]
pci_root PNP0A03:00: host bridge window [mem 0xff97c000-0xff97ffff]
pci_root PNP0A03:00: host bridge window [mem 0xfed20000-0xfed9ffff]
PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io  0x0000-0x03af]
pci_bus 0000:00: root bus resource [io  0x03b0-0x03bb]
pci_bus 0000:00: root bus resource [io  0x03bc-0x03bf]
pci_bus 0000:00: root bus resource [io  0x03c0-0x03df]
pci_bus 0000:00: root bus resource [io  0x03e0-0x0cf7]
pci_bus 0000:00: root bus resource [io  0x0d00-0xefff]
pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000effff]
pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff]
pci_bus 0000:00: root bus resource [mem 0xe8000000-0xf7ffffff]
pci_bus 0000:00: root bus resource [mem 0xd7f00000-0xe6ffffff]
pci_bus 0000:00: root bus resource [mem 0xff980000-0xff980fff]
pci_bus 0000:00: root bus resource [mem 0xff97c000-0xff97ffff]
pci_bus 0000:00: root bus resource [mem 0xfed20000-0xfed9ffff]
pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
pci 0000:00:00.0: PME# disabled
pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
pci 0000:00:01.0: PME# disabled
pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
pci 0000:00:03.0: PME# disabled
pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
pci 0000:00:07.0: PME# disabled
pci 0000:00:1a.0: reg 20: [io  0x1f20-0x1f3f]
pci 0000:00:1a.1: reg 20: [io  0x1f00-0x1f1f]
pci 0000:00:1a.2: reg 20: [io  0x1c00-0x1c1f]
pci 0000:00:1a.7: reg 10: [mem 0xf7ffa000-0xf7ffa3ff]
pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
pci 0000:00:1a.7: PME# disabled
pci 0000:00:1b.0: reg 10: [mem 0xf7ffc000-0xf7ffffff 64bit]
pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
pci 0000:00:1b.0: PME# disabled
pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
pci 0000:00:1c.0: PME# disabled
pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
pci 0000:00:1c.5: PME# disabled
pci 0000:00:1d.0: reg 20: [io  0x1f80-0x1f9f]
pci 0000:00:1d.1: reg 20: [io  0x1f60-0x1f7f]
pci 0000:00:1d.2: reg 20: [io  0x1f40-0x1f5f]
pci 0000:00:1d.7: reg 10: [mem 0xff980000-0xff9803ff]
pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
pci 0000:00:1d.7: PME# disabled
pci 0000:00:1f.0: quirk: [io  0x0800-0x087f] claimed by ICH6 ACPI/GPIO/TCO
pci 0000:00:1f.0: quirk: [io  0x0880-0x08bf] claimed by ICH6 GPIO
pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0c00 (mask 007f)
pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 00e0 (mask 0007)
pci 0000:00:1f.0: ICH7 LPC Generic IO decode 3 PIO at 0900 (mask 003f)
pci 0000:00:1f.2: reg 10: [io  0x1e00-0x1e07]
pci 0000:00:1f.2: reg 14: [io  0x1e10-0x1e13]
pci 0000:00:1f.2: reg 18: [io  0x1e20-0x1e27]
pci 0000:00:1f.2: reg 1c: [io  0x1e30-0x1e33]
pci 0000:00:1f.2: reg 20: [io  0x1ec0-0x1edf]
pci 0000:00:1f.2: reg 24: [mem 0xff970000-0xff9707ff]
pci 0000:00:1f.2: PME# supported from D3hot
pci 0000:00:1f.2: PME# disabled
pci 0000:00:1f.3: reg 10: [mem 0xf7ffb000-0xf7ffb0ff 64bit]
pci 0000:00:1f.3: reg 20: [io  0xece0-0xecff]
pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
pci 0000:01:00.0: PME# disabled
pci 0000:00:01.0: PCI bridge to [bus 01-02]
pci 0000:00:01.0:   bridge window [io  0xf000-0x0000] (disabled)
pci 0000:00:01.0:   bridge window [mem 0xf5e00000-0xf5efffff]
pci 0000:00:01.0:   bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
pci 0000:01:00.0: PCI bridge to [bus 02-02]
pci 0000:01:00.0:   bridge window [io  0xf000-0x0000] (disabled)
pci 0000:01:00.0:   bridge window [mem 0xfff00000-0x000fffff] (disabled)
pci 0000:01:00.0:   bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
pci 0000:03:00.0: reg 10: [mem 0xf6000000-0xf6ffffff]
pci 0000:03:00.0: reg 14: [mem 0xe8000000-0xefffffff 64bit pref]
pci 0000:03:00.0: reg 1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
pci 0000:03:00.0: reg 24: [io  0xdc80-0xdcff]
pci 0000:03:00.0: reg 30: [mem 0xf7e00000-0xf7e7ffff pref]
pci 0000:03:00.1: reg 10: [mem 0xf7dfc000-0xf7dfffff]
pci 0000:00:03.0: PCI bridge to [bus 03-03]
pci 0000:00:03.0:   bridge window [io  0xd000-0xdfff]
pci 0000:00:03.0:   bridge window [mem 0xf6000000-0xf7efffff]
pci 0000:00:03.0:   bridge window [mem 0xe8000000-0xf1ffffff 64bit pref]
pci 0000:00:07.0: PCI bridge to [bus 04-04]
pci 0000:00:07.0:   bridge window [io  0xf000-0x0000] (disabled)
pci 0000:00:07.0:   bridge window [mem 0xf5f00000-0xf5ffffff]
pci 0000:00:07.0:   bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
pci 0000:05:00.0: reg 10: [io  0xcc00-0xccff]
pci 0000:05:00.0: reg 14: [mem 0xf5cec000-0xf5ceffff 64bit]
pci 0000:05:00.0: reg 1c: [mem 0xf5cf0000-0xf5cfffff 64bit]
pci 0000:05:00.0: reg 30: [mem 0xf5d00000-0xf5dfffff pref]
pci 0000:05:00.0: supports D1 D2
pci 0000:00:1c.0: PCI bridge to [bus 05-05]
pci 0000:00:1c.0:   bridge window [io  0xc000-0xcfff]
pci 0000:00:1c.0:   bridge window [mem 0xf5c00000-0xf5dfffff]
pci 0000:00:1c.0:   bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
pci 0000:06:00.0: reg 10: [mem 0xf5be0000-0xf5beffff 64bit]
pci 0000:06:00.0: reg 18: [mem 0xf5bf0000-0xf5bfffff 64bit]
pci 0000:06:00.0: PME# supported from D3hot D3cold
pci 0000:06:00.0: PME# disabled
pci 0000:00:1c.5: PCI bridge to [bus 06-06]
pci 0000:00:1c.5:   bridge window [io  0xf000-0x0000] (disabled)
pci 0000:00:1c.5:   bridge window [mem 0xf5b00000-0xf5bfffff]
pci 0000:00:1c.5:   bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
pci 0000:07:0a.0: reg 10: [mem 0xf5afb000-0xf5afb7ff]
pci 0000:07:0a.0: reg 14: [mem 0xf5afc000-0xf5afffff]
pci 0000:07:0a.0: supports D1 D2
pci 0000:07:0a.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:07:0a.0: PME# disabled
pci 0000:00:1e.0: PCI bridge to [bus 07-07] (subtractive decode)
pci 0000:00:1e.0:   bridge window [io  0xf000-0x0000] (disabled)
pci 0000:00:1e.0:   bridge window [mem 0xf5a00000-0xf5afffff]
pci 0000:00:1e.0:   bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
pci 0000:00:1e.0:   bridge window [io  0x0000-0x03af] (subtractive decode)
pci 0000:00:1e.0:   bridge window [io  0x03b0-0x03bb] (subtractive decode)
pci 0000:00:1e.0:   bridge window [io  0x03bc-0x03bf] (subtractive decode)
pci 0000:00:1e.0:   bridge window [io  0x03c0-0x03df] (subtractive decode)
pci 0000:00:1e.0:   bridge window [io  0x03e0-0x0cf7] (subtractive decode)
pci 0000:00:1e.0:   bridge window [io  0x0d00-0xefff] (subtractive decode)
pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
pci 0000:00:1e.0:   bridge window [mem 0x000c0000-0x000effff] (subtractive decode)
pci 0000:00:1e.0:   bridge window [mem 0x000f0000-0x000fffff] (subtractive decode)
pci 0000:00:1e.0:   bridge window [mem 0xe8000000-0xf7ffffff] (subtractive decode)
pci 0000:00:1e.0:   bridge window [mem 0xd7f00000-0xe6ffffff] (subtractive decode)
pci 0000:00:1e.0:   bridge window [mem 0xff980000-0xff980fff] (subtractive decode)
pci 0000:00:1e.0:   bridge window [mem 0xff97c000-0xff97ffff] (subtractive decode)
pci 0000:00:1e.0:   bridge window [mem 0xfed20000-0xfed9ffff] (subtractive decode)
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI2._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI3._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI4._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI5._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI6._PRT]
 pci0000:00: Requesting ACPI _OSC control (0x1d)
Unable to assume _OSC PCIe control. Disabling ASPM
ACPI: PCI Root Bridge [PCI7] (domain 0000 [bus 20-3d])
pci_root PNP0A03:01: host bridge window [io  0xf000-0xffff]
pci_root PNP0A03:01: host bridge window [mem 0xe7000000-0xe7ffffff]
pci_root PNP0A03:01: host bridge window [mem 0x000a0000-0x000b0000]
PCI host bridge to bus 0000:20
pci_bus 0000:20: root bus resource [io  0xf000-0xffff]
pci_bus 0000:20: root bus resource [mem 0xe7000000-0xe7ffffff]
pci_bus 0000:20: root bus resource [mem 0x000a0000-0x000b0000]
pci 0000:20:03.0: PME# supported from D0 D3hot D3cold
pci 0000:20:03.0: PME# disabled
pci 0000:20:07.0: PME# supported from D0 D3hot D3cold
pci 0000:20:07.0: PME# disabled
pci 0000:20:09.0: PME# supported from D0 D3hot D3cold
pci 0000:20:09.0: PME# disabled
pci 0000:20:03.0: PCI bridge to [bus 22-22]
pci 0000:20:03.0:   bridge window [io  0xf000-0x0000] (disabled)
pci 0000:20:03.0:   bridge window [mem 0xe7f00000-0xe7ffffff]
pci 0000:20:03.0:   bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
pci 0000:20:07.0: PCI bridge to [bus 23-23]
pci 0000:20:07.0:   bridge window [io  0xf000-0x0000] (disabled)
pci 0000:20:07.0:   bridge window [mem 0xe7e00000-0xe7efffff]
pci 0000:20:07.0:   bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
pci 0000:20:09.0: PCI bridge to [bus 24-24]
pci 0000:20:09.0:   bridge window [io  0xf000-0x0000] (disabled)
pci 0000:20:09.0:   bridge window [mem 0xe7d00000-0xe7dfffff]
pci 0000:20:09.0:   bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
ACPI: PCI Interrupt Routing Table [\_SB_.PCI7._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI7.PCI9._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI7.PCIA._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI7.PCIB._PRT]
 pci0000:20: Requesting ACPI _OSC control (0x1d)
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 *10 11 12 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 9 10 11 12 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKE] (IRQs *3 4 5 6 7 9 10 11 12 15)
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 *9 10 11 12 15)
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 9 10 11 12 15)
vgaarb: device added: PCI:0000:03:00.0,decodes=io+mem,owns=io+mem,locks=none
vgaarb: loaded
vgaarb: bridge control possible 0000:03:00.0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
PCI: Using ACPI for IRQ routing
PCI: old code would have set cacheline size to 32 bytes, but clflush_size = 64
PCI: pci_cache_line_size set to 64 bytes
pci 0000:00:1f.2: no compatible bridge window for [mem 0xff970000-0xff9707ff]
pci 0000:00:1f.2: can't reserve [mem 0xff970000-0xff9707ff]
Expanded resource reserved due to conflict with PCI Bus 0000:00
NetLabel: Initializing
NetLabel:  domain hash size = 128
NetLabel:  protocols = UNLABELED CIPSOv4
NetLabel:  unlabeled traffic allowed by default
HPET: 4 timers in total, 0 timers will be used for per-cpu timer
hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
hpet0: 4 comparators, 64-bit 14.318180 MHz counter
Switching to clocksource hpet
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnp 00:00: [io  0x0cf8-0x0cff]
pnp 00:01: [io  0x0060]
pnp 00:01: [io  0x0064]
pnp 00:01: [io  0x0062-0x0063]
pnp 00:01: [io  0x0065-0x006f]
pnp 00:01: [io  0x00e0-0x00ef]
pnp 00:01: [io  0x0800-0x085f]
pnp 00:01: [io  0x0c00-0x0c7f]
pnp 00:01: [io  0x0860-0x08ff]
pnp 00:01: disabling [io  0x0800-0x085f] because it overlaps 0000:00:1f.0 BAR 13 [io  0x0800-0x087f]
pnp 00:01: disabling [io  0x0860-0x08ff] because it overlaps 0000:00:1f.0 BAR 13 [io  0x0800-0x087f]
pnp 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
pnp 00:02: [io  0x0080-0x009f]
pnp 00:02: [io  0x0000-0x001f]
pnp 00:02: [io  0x00c0-0x00df]
pnp 00:02: [dma 4]
pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
pnp 00:03: [io  0x00f0-0x00ff]
pnp 00:03: [irq 13]
pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
pnp 00:04: [io  0x0061]
pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
pnp 00:05: [io  0x0070-0x007f]
pnp 00:05: [irq 8]
pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
pnp 00:06: [io  0x0378-0x037f]
pnp 00:06: [io  0x0778-0x077f]
pnp 00:06: [irq 7]
pnp 00:06: [dma 0 disabled]
pnp 00:06: Plug and Play ACPI device, IDs PNP0401 (active)
pnp 00:07: [io  0x03f8-0x03ff]
pnp 00:07: [irq 4]
pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
pnp 00:08: Plug and Play ACPI device, IDs PNP0a03 (active)
pnp 00:09: [mem 0xfed00000-0xfed003ff]
pnp 00:09: Plug and Play ACPI device, IDs PNP0103 (active)
pnp: PnP ACPI: found 10 devices
ACPI: ACPI bus type pnp unregistered
system 00:01: [io  0x0c00-0x0c7f] has been reserved
PCI: max bus depth: 2 pci_try_num: 3
pci 0000:00:1f.2: BAR 5: assigned [mem 0xf2000000-0xf20007ff]
pci 0000:00:1f.2: BAR 5: set to [mem 0xf2000000-0xf20007ff] (PCI address [0xf2000000-0xf20007ff]
pci 0000:00:1c.5: BAR 15: assigned [mem 0xf2100000-0xf22fffff 64bit pref]
pci 0000:00:1c.5: BAR 13: assigned [io  0x2000-0x2fff]
pci 0000:00:1c.0: BAR 15: assigned [mem 0xf2300000-0xf24fffff 64bit pref]
pci 0000:01:00.0:   bridge window [io  disabled]
pci 0000:01:00.0:   bridge window [mem disabled]
pci 0000:01:00.0:   bridge window [mem pref disabled]
pci 0000:00:01.0:   bridge window [io  disabled]
pci 0000:00:01.0:   bridge window [mem pref disabled]
pci 0000:00:07.0:   bridge window [io  disabled]
pci 0000:00:07.0:   bridge window [mem pref disabled]
pci 0000:00:1c.0:   bridge window [mem 0xf2300000-0xf24fffff 64bit pref]
pci 0000:00:1c.5:   bridge window [io  0x2000-0x2fff]
pci 0000:00:1c.5:   bridge window [mem 0xf2100000-0xf22fffff 64bit pref]
pci 0000:00:1e.0:   bridge window [io  disabled]
pci 0000:00:1e.0:   bridge window [mem pref disabled]
pci 0000:20:03.0:   bridge window [io  disabled]
pci 0000:20:03.0:   bridge window [mem pref disabled]
pci 0000:20:07.0:   bridge window [io  disabled]
pci 0000:20:07.0:   bridge window [mem pref disabled]
pci 0000:20:09.0:   bridge window [io  disabled]
pci 0000:20:09.0:   bridge window [mem pref disabled]
  alloc irq_desc for 16 on node -1
  alloc kstat_irqs on node -1
pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
pci 0000:00:01.0: setting latency timer to 64
  alloc irq_desc for 28 on node -1
pci 0000:01:00.0: PCI INT A -> GSI 28 (level, low) -> IRQ 28
pci 0000:01:00.0: setting latency timer to 64
pci 0000:00:03.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
pci 0000:00:03.0: setting latency timer to 64
pci 0000:00:07.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
pci 0000:00:07.0: setting latency timer to 64
pci 0000:00:1c.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
pci 0000:00:1c.0: setting latency timer to 64
  alloc irq_desc for 17 on node -1
pci 0000:00:1c.5: PCI INT B -> GSI 17 (level, low) -> IRQ 17
pci 0000:00:1c.5: setting latency timer to 64
pci 0000:00:1e.0: setting latency timer to 64
pci 0000:20:03.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
pci 0000:20:03.0: setting latency timer to 64
pci 0000:20:07.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
pci 0000:20:07.0: setting latency timer to 64
pci 0000:20:09.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
pci 0000:20:09.0: setting latency timer to 64
pci_bus 0000:00: resource 4 [io  0x0000-0x03af]
pci_bus 0000:00: resource 5 [io  0x03b0-0x03bb]
pci_bus 0000:00: resource 6 [io  0x03bc-0x03bf]
pci_bus 0000:00: resource 7 [io  0x03c0-0x03df]
pci_bus 0000:00: resource 8 [io  0x03e0-0x0cf7]
pci_bus 0000:00: resource 9 [io  0x0d00-0xefff]
pci_bus 0000:00: resource 10 [mem 0x000a0000-0x000bffff]
pci_bus 0000:00: resource 11 [mem 0x000c0000-0x000effff]
pci_bus 0000:00: resource 12 [mem 0x000f0000-0x000fffff]
pci_bus 0000:00: resource 13 [mem 0xe8000000-0xf7ffffff]
pci_bus 0000:00: resource 14 [mem 0xd7f00000-0xe6ffffff]
pci_bus 0000:00: resource 15 [mem 0xff980000-0xff980fff]
pci_bus 0000:00: resource 16 [mem 0xff97c000-0xff97ffff]
pci_bus 0000:00: resource 17 [mem 0xfed20000-0xfed9ffff]
pci_bus 0000:01: resource 1 [mem 0xf5e00000-0xf5efffff]
pci_bus 0000:03: resource 0 [io  0xd000-0xdfff]
pci_bus 0000:03: resource 1 [mem 0xf6000000-0xf7efffff]
pci_bus 0000:03: resource 2 [mem 0xe8000000-0xf1ffffff 64bit pref]
pci_bus 0000:04: resource 1 [mem 0xf5f00000-0xf5ffffff]
pci_bus 0000:05: resource 0 [io  0xc000-0xcfff]
pci_bus 0000:05: resource 1 [mem 0xf5c00000-0xf5dfffff]
pci_bus 0000:05: resource 2 [mem 0xf2300000-0xf24fffff 64bit pref]
pci_bus 0000:06: resource 0 [io  0x2000-0x2fff]
pci_bus 0000:06: resource 1 [mem 0xf5b00000-0xf5bfffff]
pci_bus 0000:06: resource 2 [mem 0xf2100000-0xf22fffff 64bit pref]
pci_bus 0000:07: resource 1 [mem 0xf5a00000-0xf5afffff]
pci_bus 0000:07: resource 4 [io  0x0000-0x03af]
pci_bus 0000:07: resource 5 [io  0x03b0-0x03bb]
pci_bus 0000:07: resource 6 [io  0x03bc-0x03bf]
pci_bus 0000:07: resource 7 [io  0x03c0-0x03df]
pci_bus 0000:07: resource 8 [io  0x03e0-0x0cf7]
pci_bus 0000:07: resource 9 [io  0x0d00-0xefff]
pci_bus 0000:07: resource 10 [mem 0x000a0000-0x000bffff]
pci_bus 0000:07: resource 11 [mem 0x000c0000-0x000effff]
pci_bus 0000:07: resource 12 [mem 0x000f0000-0x000fffff]
pci_bus 0000:07: resource 13 [mem 0xe8000000-0xf7ffffff]
pci_bus 0000:07: resource 14 [mem 0xd7f00000-0xe6ffffff]
pci_bus 0000:07: resource 15 [mem 0xff980000-0xff980fff]
pci_bus 0000:07: resource 16 [mem 0xff97c000-0xff97ffff]
pci_bus 0000:07: resource 17 [mem 0xfed20000-0xfed9ffff]
pci_bus 0000:20: resource 4 [io  0xf000-0xffff]
pci_bus 0000:20: resource 5 [mem 0xe7000000-0xe7ffffff]
pci_bus 0000:20: resource 6 [mem 0x000a0000-0x000b0000]
pci_bus 0000:22: resource 1 [mem 0xe7f00000-0xe7ffffff]
pci_bus 0000:23: resource 1 [mem 0xe7e00000-0xe7efffff]
pci_bus 0000:24: resource 1 [mem 0xe7d00000-0xe7dfffff]
NET: Registered protocol family 2
IP route cache hash table entries: 524288 (order: 10, 4194304 bytes)
TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
TCP: Hash tables configured (established 524288 bind 65536)
TCP reno registered
pci 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
pci 0000:00:1a.0: PCI INT A disabled
pci 0000:00:1a.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
pci 0000:00:1a.1: PCI INT B disabled
  alloc irq_desc for 22 on node -1
pci 0000:00:1a.2: PCI INT C -> GSI 22 (level, low) -> IRQ 22
pci 0000:00:1a.2: PCI INT C disabled
pci 0000:00:1a.7: PCI INT C -> GSI 22 (level, low) -> IRQ 22
pci 0000:00:1a.7: PCI INT C disabled
  alloc irq_desc for 23 on node -1
pci 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
pci 0000:00:1d.0: PCI INT A disabled
pci 0000:00:1d.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
pci 0000:00:1d.1: PCI INT B disabled
  alloc irq_desc for 18 on node -1
pci 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
pci 0000:00:1d.2: PCI INT C disabled
pci 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
pci 0000:00:1d.7: PCI INT A disabled
pci 0000:03:00.0: Boot video device
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 17124k freed
Simple Boot Flag at 0x7a set to 0x80
audit: initializing netlink socket (disabled)
type=2000 audit(1409325528.980:1): initialized
HugeTLB registered 2 MB page size, pre-allocated 0 pages
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
msgmni has been set to 32768
SELinux:  Registering netfilter hooks
alg: No test for stdrng (krng)
ksign: Installing public key data
Loading keyring
- Added public key CF375B5228EA687
- User ID: CentOS (Kernel Module GPG key)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
pcieport 0000:00:1c.0: setting latency timer to 64
  alloc irq_desc for 72 on node -1
pcieport 0000:00:1c.0: irq 72 for MSI/MSI-X
pcieport 0000:00:1c.5: setting latency timer to 64
  alloc irq_desc for 73 on node -1
pcieport 0000:00:1c.5: irq 73 for MSI/MSI-X
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
pciehp: PCI Express Hot Plug Controller Driver version: 0.4
acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
intel_idle: MWAIT substates: 0x1120
intel_idle: v0.4 model 0x2C
intel_idle: lapic_timer_reliable_states 0xffffffff
ipmi message handler version 39.2
IPMI System Interface driver.
ipmi_si: Adding default-specified kcs state machine
ipmi_si: Trying default-specified kcs state machine at i/o address 0xca2, slave address 0x0, irq 0
ipmi_si: Interface detection failed
ipmi_si: Adding default-specified smic state machine
ipmi_si: Trying default-specified smic state machine at i/o address 0xca9, slave address 0x0, irq 0
ipmi_si: Adding default-specified bt state machine
ipmi_si: Trying default-specified bt state machine at i/o address 0xe4, slave address 0x0, irq 0
ipmi_si: Unable to find any System Interface(s)
input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
ACPI: Power Button [VBTN]
input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
ACPI: Power Button [PWRF]
ACPI: acpi_idle yielding to intel_idle
[Firmware Bug]: No valid trip found
GHES: HEST is not enabled!
Non-volatile memory driver v1.3
Linux agpgart interface v0.103
crash memory driver: version 1.1
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
brd: module loaded
loop: module loaded
input: Macintosh mouse button emulation as /devices/virtual/input/input2
Fixed MDIO Bus: probed
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 22 (level, low) -> IRQ 22
ehci_hcd 0000:00:1a.7: setting latency timer to 64
ehci_hcd 0000:00:1a.7: EHCI Host Controller
ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:1a.7: debug port 1
ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
ehci_hcd 0000:00:1a.7: irq 22, io mem 0xf7ffa000
ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.32-431.23.3.el6.x86_64 ehci_hcd
usb usb1: SerialNumber: 0000:00:1a.7
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 6 ports detected
ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
ehci_hcd 0000:00:1d.7: setting latency timer to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
ehci_hcd 0000:00:1d.7: debug port 1
ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
ehci_hcd 0000:00:1d.7: irq 23, io mem 0xff980000
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: EHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.32-431.23.3.el6.x86_64 ehci_hcd
usb usb2: SerialNumber: 0000:00:1d.7
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 6 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
uhci_hcd: USB Universal Host Controller Interface driver
uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
uhci_hcd 0000:00:1a.0: setting latency timer to 64
uhci_hcd 0000:00:1a.0: UHCI Host Controller
uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1a.0: irq 16, io base 0x00001f20
usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb3: Product: UHCI Host Controller
usb usb3: Manufacturer: Linux 2.6.32-431.23.3.el6.x86_64 uhci_hcd
usb usb3: SerialNumber: 0000:00:1a.0
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
uhci_hcd 0000:00:1a.1: setting latency timer to 64
uhci_hcd 0000:00:1a.1: UHCI Host Controller
uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:1a.1: irq 17, io base 0x00001f00
usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb4: Product: UHCI Host Controller
usb usb4: Manufacturer: Linux 2.6.32-431.23.3.el6.x86_64 uhci_hcd
usb usb4: SerialNumber: 0000:00:1a.1
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
uhci_hcd 0000:00:1a.2: PCI INT C -> GSI 22 (level, low) -> IRQ 22
uhci_hcd 0000:00:1a.2: setting latency timer to 64
uhci_hcd 0000:00:1a.2: UHCI Host Controller
uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
uhci_hcd 0000:00:1a.2: irq 22, io base 0x00001c00
usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb5: Product: UHCI Host Controller
usb usb5: Manufacturer: Linux 2.6.32-431.23.3.el6.x86_64 uhci_hcd
usb usb5: SerialNumber: 0000:00:1a.2
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 2 ports detected
uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
uhci_hcd 0000:00:1d.0: setting latency timer to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
uhci_hcd 0000:00:1d.0: irq 23, io base 0x00001f80
usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb6: Product: UHCI Host Controller
usb usb6: Manufacturer: Linux 2.6.32-431.23.3.el6.x86_64 uhci_hcd
usb usb6: SerialNumber: 0000:00:1d.0
usb usb6: configuration #1 chosen from 1 choice
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 2 ports detected
uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
uhci_hcd 0000:00:1d.1: setting latency timer to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
uhci_hcd 0000:00:1d.1: irq 17, io base 0x00001f60
usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb7: Product: UHCI Host Controller
usb usb7: Manufacturer: Linux 2.6.32-431.23.3.el6.x86_64 uhci_hcd
usb usb7: SerialNumber: 0000:00:1d.1
usb usb7: configuration #1 chosen from 1 choice
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 2 ports detected
uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
uhci_hcd 0000:00:1d.2: setting latency timer to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
uhci_hcd 0000:00:1d.2: irq 18, io base 0x00001f40
usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb8: Product: UHCI Host Controller
usb usb8: Manufacturer: Linux 2.6.32-431.23.3.el6.x86_64 uhci_hcd
usb usb8: SerialNumber: 0000:00:1d.2
usb usb8: configuration #1 chosen from 1 choice
hub 8-0:1.0: USB hub found
hub 8-0:1.0: 2 ports detected
PNP: No PS/2 controller found. Probing ports directly.
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
mice: PS/2 mouse device common for all mice
rtc_cmos 00:05: RTC can wake from S4
rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
rtc0: alarms up to one day, 242 bytes nvram, hpet irqs
cpuidle: using governor ladder
cpuidle: using governor menu
EFI Variables Facility v0.08 2004-May-17
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
GRE over IPv4 demultiplexor driver
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 17
registered taskstats version 1
rtc_cmos 00:05: setting system clock to 2014-08-29 15:18:50 UTC (1409325530)
Initalizing network drop monitor service
Freeing unused kernel memory: 1280k freed
Write protecting the kernel read-only data: 10240k
Freeing unused kernel memory: 796k freed
Freeing unused kernel memory: 1584k freed
dracut: dracut-004-336.el6_5.2
dracut: rd_NO_LUKS: removing cryptoluks activation
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.24.6-ioctl (2013-01-15) initialised: dm-devel@redhat.com
udev: starting version 147
dracut: Starting plymouth daemon
dracut: rd_NO_DM: removing DM RAID activation
dracut: rd_NO_MD: removing MD RAID activation
Fusion MPT base driver 3.04.20
Copyright (c) 1999-2008 LSI Corporation
Fusion MPT SAS Host driver 3.04.20
mptsas 0000:05:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
mptbase: ioc0: Initiating bringup
ioc0: LSISAS1068E B3: Capabilities={Initiator}
mptsas 0000:05:00.0: setting latency timer to 64
Refined TSC clocksource calibration: 3590.999 MHz.
Switching to clocksource tsc
usb 3-1: new low speed USB device number 2 using uhci_hcd
usb 3-1: New USB device found, idVendor=413c, idProduct=2003
usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 3-1: Product: Dell USB Keyboard
usb 3-1: Manufacturer: Dell
usb 3-1: configuration #1 chosen from 1 choice
input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1:1.0/input/input3
generic-usb 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:1a.0-1/input0
usb 3-2: new low speed USB device number 3 using uhci_hcd
usb 3-2: New USB device found, idVendor=04b3, idProduct=310c
usb 3-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
usb 3-2: Product: USB Optical Mouse
usb 3-2: configuration #1 chosen from 1 choice
input: USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.0/input/input4
generic-usb 0003:04B3:310C.0002: input,hidraw1: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1a.0-2/input0
usb 8-1: new full speed USB device number 2 using uhci_hcd
usb 8-1: New USB device found, idVendor=04e6, idProduct=5116
usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
usb 8-1: Product: SCR3310 USB Smart Card Reader
usb 8-1: Manufacturer: SCM Microsystems Inc.
usb 8-1: SerialNumber: 21121119205330
usb 8-1: configuration #1 chosen from 1 choice
scsi0 : ioc0: LSISAS1068E B3, FwRev=00192f00h, Ports=1, MaxQ=266, IRQ=16
mptsas: ioc0: attaching ssp device: fw_channel 0, fw_id 9, phy 0, sas_addr 0x5000c500486fcfa1
scsi 0:0:0:0: Direct-Access     SEAGATE  ST3600057SS      ES64 PQ: 0 ANSI: 5
mptsas: ioc0: attaching ssp device: fw_channel 0, fw_id 1, phy 1, sas_addr 0x5000c500486aba25
scsi 0:0:1:0: Direct-Access     SEAGATE  ST3600057SS      ES64 PQ: 0 ANSI: 5
mptsas: ioc0: attaching ssp device: fw_channel 0, fw_id 8, phy 2, sas_addr 0x5000c500486b0901
scsi 0:0:2:0: Direct-Access     SEAGATE  ST3600057SS      ES64 PQ: 0 ANSI: 5
mptsas: ioc0: attaching ssp device: fw_channel 0, fw_id 3, phy 3, sas_addr 0x5000c500486fc829
scsi 0:0:3:0: Direct-Access     SEAGATE  ST3600057SS      ES64 PQ: 0 ANSI: 5
mptsas: ioc0: attaching raid volume, channel 1, id 2
scsi 0:1:2:0: Direct-Access     Dell     VIRTUAL DISK     1028 PQ: 0 ANSI: 5
mptsas: ioc0: attaching raid volume, channel 1, id 0
scsi 0:1:0:0: Direct-Access     Dell     VIRTUAL DISK     1028 PQ: 0 ANSI: 5
ahci 0000:00:1f.2: version 3.0
  alloc irq_desc for 20 on node -1
ahci 0000:00:1f.2: PCI INT C -> GSI 20 (level, low) -> IRQ 20
  alloc irq_desc for 74 on node -1
ahci 0000:00:1f.2: irq 74 for MSI/MSI-X
ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x27 impl SATA mode
ahci 0000:00:1f.2: flags: 64bit ncq sntf led clo pio ccc ems sxs
ahci 0000:00:1f.2: setting latency timer to 64
scsi1 : ahci
scsi2 : ahci
scsi3 : ahci
scsi4 : ahci
scsi5 : ahci
scsi6 : ahci
ata1: SATA max UDMA/133 abar m2048@0xf2000000 port 0xf2000100 irq 74
ata2: SATA max UDMA/133 abar m2048@0xf2000000 port 0xf2000180 irq 74
ata3: SATA max UDMA/133 abar m2048@0xf2000000 port 0xf2000200 irq 74
ata4: DUMMY
ata5: DUMMY
ata6: SATA max UDMA/133 abar m2048@0xf2000000 port 0xf2000380 irq 74
ata6: SATA link down (SStatus 0 SControl 300)
ata3: SATA link down (SStatus 4 SControl 300)
ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata2: SATA link down (SStatus 4 SControl 300)
ata1.00: ATAPI: TSSTcorp DVD+/-RW SH-216BB, D100, max UDMA/100, ATAPI AN
ata1.00: configured for UDMA/100
scsi 1:0:0:0: CD-ROM            TSSTcorp DVD+-RW SH-216BB D100 PQ: 0 ANSI: 5
ACPI: WMI: Mapper loaded
firewire_ohci 0000:07:0a.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
firewire_ohci: Added fw-ohci device 0000:07:0a.0, OHCI version 1.10
sd 0:1:2:0: [sda] 2341994496 512-byte logical blocks: (1.19 TB/1.08 TiB)
sd 0:1:0:0: [sdb] 2341994496 512-byte logical blocks: (1.19 TB/1.08 TiB)
sd 0:1:2:0: [sda] Write Protect is off
sd 0:1:2:0: [sda] Mode Sense: 03 00 00 08
sd 0:1:0:0: [sdb] Write Protect is off
sd 0:1:0:0: [sdb] Mode Sense: 03 00 00 08
sd 0:1:2:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sd 0:1:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
 sda:
 sdb:
 sda1 sda2
sd 0:1:0:0: [sdb] Attached SCSI disk
sd 0:1:2:0: [sda] Attached SCSI disk
sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
Uniform CD-ROM driver Revision: 3.20
sr 1:0:0:0: Attached scsi CD-ROM sr0
dracut: Scanning devices sda2  for LVM logical volumes vg_ncu0124366/LogVol00 vg_ncu0124366/LogVol01
dracut: inactive '/dev/vg_ncu0124366/LogVol01' [1.01 TiB] inherit
dracut: inactive '/dev/vg_ncu0124366/LogVol00' [62.50 GiB] inherit
firewire_core: created device fw0: GUID 8073031833444f00, S400
EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts:
dracut: Mounted root filesystem /dev/mapper/vg_ncu0124366-LogVol01
dracut: Loading SELinux policy
type=1404 audit(1409325560.335:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
SELinux: 2048 avtab hash slots, 277817 rules.
SELinux:  9 users, 12 roles, 3917 types, 217 bools, 1 sens, 1024 cats
SELinux:  81 classes, 277817 rules
SELinux:  Completing initialization.
SELinux:  Setting up existing superblocks.
SELinux: initialized (dev dm-0, type ext4), uses xattr
SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
SELinux: initialized (dev usbfs, type usbfs), uses genfs_contexts
SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
SELinux: initialized (dev mqueue, type mqueue), uses transition SIDs
SELinux: initialized (dev hugetlbfs, type hugetlbfs), uses transition SIDs
SELinux: initialized (dev devpts, type devpts), uses transition SIDs
SELinux: initialized (dev inotifyfs, type inotifyfs), uses genfs_contexts
SELinux: initialized (dev anon_inodefs, type anon_inodefs), uses genfs_contexts
SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
SELinux: initialized (dev proc, type proc), uses genfs_contexts
SELinux: initialized (dev bdev, type bdev), uses genfs_contexts
SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
type=1403 audit(1409325560.665:3): policy loaded auid=4294967295 ses=4294967295
dracut:
dracut: Switching root
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
EDAC MC: Ver: 2.1.0 Jul 31 2014
snd_hda_intel 0000:00:1b.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
  alloc irq_desc for 75 on node -1
snd_hda_intel 0000:00:1b.0: irq 75 for MSI/MSI-X
snd_hda_intel 0000:00:1b.0: setting latency timer to 64
hda_codec: AD1984A: BIOS auto-probing.
input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
  alloc irq_desc for 34 on node -1
snd_hda_intel 0000:03:00.1: PCI INT B -> GSI 34 (level, low) -> IRQ 34
hda_intel: Disabling MSI
hda-intel 0000:03:00.1: Handle VGA-switcheroo audio client
snd_hda_intel 0000:03:00.1: setting latency timer to 64
input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.0/0000:03:00.1/sound/card1/input9
input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/0000:03:00.1/sound/card1/input10
input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/0000:03:00.1/sound/card1/input11
input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/0000:03:00.1/sound/card1/input12
ACPI: resource (null) [io  0x0828-0x082f] conflicts with ACPI region GLBC [io 0x828-0x82d]
ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
lpc_ich: Resource conflict(s) found affecting gpio_ich
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
tg3.c:v3.132 (May 21, 2013)
tg3 0000:06:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
tg3 0000:06:00.0: setting latency timer to 64
tg3 0000:06:00.0: eth0: Tigon3 [partno(BCM95761) rev 5761100] (PCI Express) MAC address 18:03:73:4f:44:33
tg3 0000:06:00.0: eth0: attached PHY is 5761 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
tg3 0000:06:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
tg3 0000:06:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
i801_smbus 0000:00:1f.3: PCI INT C -> GSI 20 (level, low) -> IRQ 20
nvidia: module license 'NVIDIA' taints kernel.
Disabling lock debugging due to kernel taint
  alloc irq_desc for 24 on node -1
nvidia 0000:03:00.0: PCI INT A -> GSI 24 (level, low) -> IRQ 24
nvidia 0000:03:00.0: setting latency timer to 64
vgaarb: device changed decodes: PCI:0000:03:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
NVRM: loading NVIDIA UNIX x86_64 Kernel Module  340.24  Wed Jul  2 14:24:20 PDT 2014
scsi 0:0:0:0: Attached scsi generic sg0 type 0
scsi 0:0:1:0: Attached scsi generic sg1 type 0
scsi 0:0:2:0: Attached scsi generic sg2 type 0
scsi 0:0:3:0: Attached scsi generic sg3 type 0
sd 0:1:2:0: Attached scsi generic sg4 type 0
sd 0:1:0:0: Attached scsi generic sg5 type 0
sr 1:0:0:0: Attached scsi generic sg6 type 5
parport_pc 00:06: reported by Plug and Play ACPI
parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
microcode: CPU0 sig=0x206c2, pf=0x1, revision=0x10
platform microcode: firmware: requesting intel-ucode/06-2c-02
microcode: CPU1 sig=0x206c2, pf=0x1, revision=0x10
microcode: CPU2 sig=0x206c2, pf=0x1, revision=0x10
microcode: CPU3 sig=0x206c2, pf=0x1, revision=0x10
microcode: CPU4 sig=0x206c2, pf=0x1, revision=0x10
microcode: CPU5 sig=0x206c2, pf=0x1, revision=0x10
microcode: CPU6 sig=0x206c2, pf=0x1, revision=0x10
microcode: CPU7 sig=0x206c2, pf=0x1, revision=0x10
Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
iTCO_vendor_support: vendor-support=0
iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07rh
iTCO_wdt: Found a ICH10R TCO device (Version=2, TCOBASE=0x0860)
iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
ppdev: user-space parallel port driver
vnet: mode: dma, buffers: 62
mic: No MIC boards present.  SCIF available in loopback mode
EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts:
SELinux: initialized (dev sda1, type ext4), uses xattr
Adding 65535992k swap on /dev/mapper/vg_ncu0124366-LogVol00.  Priority:-1 extents:1 across:65535992k
SELinux: initialized (dev binfmt_misc, type binfmt_misc), uses genfs_contexts
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
ip6_tables: (C) 2000-2006 Netfilter Core Team
nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
  alloc irq_desc for 76 on node -1
tg3 0000:06:00.0: irq 76 for MSI/MSI-X
ADDRCONF(NETDEV_UP): eth0: link is not ready
tg3 0000:06:00.0: eth0: Link is up at 100 Mbps, full duplex
tg3 0000:06:00.0: eth0: Flow control is off for TX and off for RX
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
p4-clockmod: Warning: EST-capable CPU detected. The acpi-cpufreq module offers voltage scaling in addition to frequency scaling. You should use that instead of p4-clockmod, if possible.
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
SELinux: initialized (dev autofs, type autofs), uses genfs_contexts
  alloc irq_desc for 77 on node -1
nvidia 0000:03:00.0: irq 77 for MSI/MSI-X
eth0: no IPv6 routers present
hda-intel: IRQ timing workaround is activated for card #1. Suggest a bigger bdl_pos_adj.
(END)
[ad_fsc_wge@ncu0124366 ~]$ /mic
-bash : /mic: No such file or directory
[ad_fsc_wge@ncu0124366 ~]$ sudo find / -name 'mic'[sudo]
password for ad_fsc_wge:
/sys/devices/virtual/mic
/sys/bus/pci/drivers/mic
/sys/class/mic
/sys/module/mic
/dev/mic
/usr/share/locale/mic
/usr/include/mic
/opt/intel/mic
/opt/mpss/3.3/sysroots/k1om-mpss-linux/usr/include/mic
[ad_fsc_wge@ncu0124366 ~]$ lspci -vvv
00:00.0 Host bridge: Intel Corporation 5520 I/O Hub to ESI Port (rev 22)
        Subsystem: Dell Device 026d
        Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Interrupt: pin A routed to IRQ 11
        Capabilities: <access denied>
00:01.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 1 (rev 22) (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Latency: 0, Cache Line Size: 64 bytes
        Bus: primary=00, secondary=01, subordinate=02, sec-latency=0
        I/O behind bridge: 0000f000-00000fff
        Memory behind bridge: f5e00000-f5efffff
        Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
        BridgeCtl: Parity- SERR+ NoISA- VGA- MAbort- >Reset- FastB2B-
                PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Kernel modules: shpchp
00:03.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 3 (rev 22) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
        I/O behind bridge: 0000d000-0000dfff
        Memory behind bridge: f6000000-f7efffff
        Prefetchable memory behind bridge: 00000000e8000000-00000000f1ffffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
        BridgeCtl: Parity- SERR+ NoISA- VGA+ MAbort- >Reset- FastB2B-
00:07.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 7 (rev 22) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
        Memory behind bridge: f5f00000-f5ffffff
00:14.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub System Management Registers (rev 22) (prog-if 00 [8259])
        Subsystem: Device 0028:006d
        Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Kernel modules: i7core_edac
00:14.1 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers (rev 22) (prog-if 00 [8259])
00:14.2 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers (rev 22) (prog-if 00 [8259])
00:1a.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4 (prog-if 00 [UHCI])
        Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 16
        Region 4: I/O ports at 1f20 [size=32]
        Kernel driver in use: uhci_hcd
00:1a.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5 (prog-if 00 [UHCI])
        Latency: 0
        Interrupt: pin B routed to IRQ 17
        Region 4: I/O ports at 1f00 [size=32]
00:1a.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6 (prog-if 00 [UHCI])
        Latency: 0
        Interrupt: pin C routed to IRQ 22
        Region 4: I/O ports at 1c00 [size=32]
00:1a.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2 (prog-if 20 [EHCI])
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Latency: 0
        Region 0: Memory at f7ffa000 (32-bit, non-prefetchable) [size=1K]
        Kernel driver in use: ehci_hcd
00:1b.0 Audio device: Intel Corporation 82801JI (ICH10 Family) HD Audio Controller
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
        Interrupt: pin A routed to IRQ 75
        Region 0: Memory at f7ffc000 (64-bit, non-prefetchable) [size=16K]
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd-hda-intel
00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1 (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
        Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
        I/O behind bridge: 0000c000-0000cfff
        Memory behind bridge: f5c00000-f5dfffff
        Prefetchable memory behind bridge: 00000000f2300000-00000000f24fffff
        Kernel driver in use: pcieport
00:1c.5 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 6 (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
        I/O behind bridge: 00002000-00002fff
        Memory behind bridge: f5b00000-f5bfffff
        Prefetchable memory behind bridge: 00000000f2100000-00000000f22fffff
00:1d.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1 (prog-if 00 [UHCI])
        Latency: 0
        Interrupt: pin A routed to IRQ 23
        Region 4: I/O ports at 1f80 [size=32]
00:1d.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2 (prog-if 00 [UHCI])
        Latency: 0
        Region 4: I/O ports at 1f60 [size=32]
00:1d.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3 (prog-if 00 [UHCI])
        Latency: 0
        Interrupt: pin C routed to IRQ 18
        Region 4: I/O ports at 1f40 [size=32]
00:1d.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1 (prog-if 20 [EHCI])
        Latency: 0
        Region 0: Memory at ff980000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90) (prog-if 01 [Subtractive decode])
        Latency: 0
        Bus: primary=00, secondary=07, subordinate=07, sec-latency=32
        Memory behind bridge: f5a00000-f5afffff
        Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
00:1f.0 ISA bridge: Intel Corporation 82801JIR (ICH10R) LPC Interface Controller
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Kernel driver in use: lpc_ich
        Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 82801JI (ICH10 Family) SATA AHCI Controller (prog-if 01 [AHCI 1.0])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin C routed to IRQ 74
        Region 0: I/O ports at 1e00 [size=8]
        Region 1: I/O ports at 1e10 [size=4]
        Region 2: I/O ports at 1e20 [size=8]
        Region 3: I/O ports at 1e30 [size=4]
        Region 4: I/O ports at 1ec0 [size=32]
        Region 5: Memory at f2000000 (32-bit, non-prefetchable) [size=2K]
        Kernel driver in use: ahci
        Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 82801JI (ICH10 Family) SMBus Controller
        Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Interrupt: pin C routed to IRQ 20
        Region 0: Memory at f7ffb000 (64-bit, non-prefetchable) [size=256]
        Region 4: I/O ports at ece0 [size=32]
        Kernel driver in use: i801_smbus
        Kernel modules: i2c-i801
01:00.0 PCI bridge: Pericom Semiconductor PCI Express to PCI-XPI7C9X130 PCI-X Bridge (rev 04) (prog-if 00 [Normal decode])
        Bus: primary=01, secondary=02, subordinate=02, sec-latency=64
        Memory behind bridge: fff00000-000fffff
        Secondary status: 66MHz+ FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
03:00.0 VGA compatible controller: NVIDIA Corporation Device 100c (rev a1) (prog-if 00 [VGA controller])
        Subsystem: eVga.com. Corp. Device 3791
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 77
        Region 0: Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
        Region 1: Memory at e8000000 (64-bit, prefetchable) [size=128M]
        Region 3: Memory at f0000000 (64-bit, prefetchable) [size=32M]
        Region 5: I/O ports at dc80 [size=128]
        [virtual] Expansion ROM at f7e00000 [disabled] [size=512K]
        Kernel driver in use: nvidia
        Kernel modules: nvidia, nouveau, nvidiafb
03:00.1 Audio device: NVIDIA Corporation GK110 HDMI Audio (rev a1)
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Interrupt: pin B routed to IRQ 34
        Region 0: Memory at f7dfc000 (32-bit, non-prefetchable) [size=16K]
05:00.0 SCSI storage controller: LSI Logic / Symbios Logic SAS1068E PCI-Express Fusion-MPT SAS (rev 08)
        Subsystem: Dell SAS 6/iR Integrated Workstations RAID Controller
        Region 0: I/O ports at cc00 [size=256]
        Region 1: Memory at f5cec000 (64-bit, non-prefetchable) [size=16K]
        Region 3: Memory at f5cf0000 (64-bit, non-prefetchable) [size=64K]
        Expansion ROM at f5d00000 [disabled] [size=1M]
        Kernel driver in use: mptsas
        Kernel modules: mptsas
06:00.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5761 Gigabit Ethernet PCIe (rev 10)
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Interrupt: pin A routed to IRQ 76
        Region 0: Memory at f5be0000 (64-bit, non-prefetchable) [size=64K]
        Region 2: Memory at f5bf0000 (64-bit, non-prefetchable) [size=64K]
        Kernel driver in use: tg3
        Kernel modules: tg3
07:0a.0 FireWire (IEEE 1394): Texas Instruments TSB43AB22A IEEE-1394a-2000 Controller (PHY/Link) [iOHCI-Lynx] (prog-if 10 [OHCI])
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Latency: 64 (500ns min, 1000ns max), Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 18
        Region 0: Memory at f5afb000 (32-bit, non-prefetchable) [size=2K]
        Region 1: Memory at f5afc000 (32-bit, non-prefetchable) [size=16K]
        Kernel driver in use: firewire_ohci
        Kernel modules: firewire-ohci
20:03.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 3 (rev 22) (prog-if 00 [Normal decode])
        Bus: primary=20, secondary=22, subordinate=22, sec-latency=0
        Memory behind bridge: e7f00000-e7ffffff
20:07.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 7 (rev 22) (prog-if 00 [Normal decode])
        Bus: primary=20, secondary=23, subordinate=23, sec-latency=0
        Memory behind bridge: e7e00000-e7efffff
20:09.0 PCI bridge: Intel Corporation 7500/5520/5500/X58 I/O Hub PCI Express Root Port 9 (rev 22) (prog-if 00 [Normal decode])
        Bus: primary=20, secondary=24, subordinate=24, sec-latency=0
        Memory behind bridge: e7d00000-e7dfffff
20:14.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub System Management Registers (rev 22) (prog-if 00 [8259])
20:14.1 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers (rev 22) (prog-if 00 [8259])
20:14.2 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers (rev 22) (prog-if 00 [8259])
[ad_fsc_wge@ncu0124366 ~]$ /Co-processor
-bash: /Co-processor: No such file or directory
Sunny_G_Intel
Hi Weigong,
Thanks for posting the output. The two searches which I suggested to use ("/mic " and "/Co-processor") were supposed to be ran as a basic pattern search on your output for "dmesg | less" and "lspci -vvv | less". The idea was to selectively look for only Co-processor related details.
From your output, one line which relates to the issue is:
One of the requirements to use a Co-processor is that the motherboard BIOS must support memory mapped I/O above 4GB (large Base Address Register support per the PCIe specification).
So when you get a chance please confirm that the host motherboard BIOS has support for memory mapped I/O above 4GB and it is enabled.
Also can you please share what kind of Co-processor card you are trying to install and what is the power specs for your host system.
Weigong_G_
Hi Sunny,
The host computer is Dell T7500 workstation. On this computer, it has 8 core of Intel 5520 CPU, 24GB RAM, and 1100W power.  I install a EVGA GeForce TITAN BLACK Superclocked Signature 06G-P4-3793-KR card on the PCI x16 slot. Both of 8-pin and 6-pin power code are connecting to the card.
On the BIOS setup, I do not find the memory mapping option. I think the T7500 is the highest performance workstation from Dell in 2, or 3 years ago. it should be support large memory for PCI.
Weigong
Sunny_G_Intel
Hi Weigong,
Motherboard BIOS support for memory mapped I/O above 4GB (large Base Address Register) is essential.
Some possible hints to access the BIOS setting for extended MMIO are:
Enter your BIOS --> Look for Advanced Settings --> Look for PCI Setttings --> Look for  Memory Mapped IO above 4GB or Large Base Address or Large BAR support  --> Try to enable that setting  --> Save and exit
Also can you please share the version of your BIOS.
dmidecode -t bios -q
In case you don't want to share this information publicly you are welcome to send me a private message by clicking "Send Author a message"
Evan_P_Intel
Weigong G. wrote:
The host computer is Dell T7500 workstation. ... I install a EVGA GeForce TITAN BLACK Superclocked Signature 06G-P4-3793-KR card on the PCI x16 slot.
And what model of Xeon Phi card do you have?
Weigong_G_
There is the CPU information below. It has 8 of processes.
[ad_fsc_wge@ncu0124366 ~]$ cat /proc/cpuinfo
processor       : 0
vendor_id       : GenuineIntel
cpu family      : 6
model           : 44
model name      : Intel(R) Xeon(R) CPU           X5687  @ 3.60GHz
stepping        : 2
cpu MHz         : 1596.000
cache size      : 12288 KB
physical id     : 1
siblings        : 4
core id         : 0
cpu cores       : 4
apicid          : 32
initial apicid  : 32
fpu             : yes
fpu_exception   : yes
cpuid level     : 11
wp              : yes
flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebsbts rep_good xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid dca sse4_1 sse4_2 popcnt aes lahf_lm ida arat epb dts tpr_shadow vnmi flex priority ept vpid
bogomips        : 7181.88
clflush size    : 64
cache_alignment : 64
address sizes   : 40 bits physical, 48 bits virtual
power management:
processor       : 1
cpu family      : 6
model           : 44
stepping        : 2
cpu MHz         : 1596.000
physical id     : 1
siblings        : 4
core id         : 1
cpu cores       : 4
apicid          : 34
initial apicid  : 34
fpu             : yes
fpu_exception   : yes
cpuid level     : 11
wp              : yes
bogomips        : 7181.88
clflush size    : 64
power management:
processor       : 2
cpu family      : 6
model           : 44
stepping        : 2
cpu MHz         : 1596.000
physical id     : 1
siblings        : 4
core id         : 9
cpu cores       : 4
apicid          : 50
initial apicid  : 50
fpu             : yes
fpu_exception   : yes
cpuid level     : 11
wp              : yes
bogomips        : 7181.88
clflush size    : 64
power management:
processor       : 3
cpu family      : 6
model           : 44
stepping        : 2
cpu MHz         : 1596.000
physical id     : 1
siblings        : 4
core id         : 10
cpu cores       : 4
apicid          : 52
initial apicid  : 52
fpu             : yes
fpu_exception   : yes
cpuid level     : 11
wp              : yes
bogomips        : 7181.88
clflush size    : 64
power management:
processor       : 4
cpu family      : 6
model           : 44
stepping        : 2
cpu MHz         : 1596.000
physical id     : 0
siblings        : 4
core id         : 0
cpu cores       : 4
apicid          : 0
initial apicid  : 0
fpu             : yes
fpu_exception   : yes
cpuid level     : 11
wp              : yes
bogomips        : 7181.66
clflush size    : 64
power management:
processor       : 5
cpu family      : 6
model           : 44
stepping        : 2
cpu MHz         : 1596.000
physical id     : 0
siblings        : 4
core id         : 1
cpu cores       : 4
apicid          : 2
initial apicid  : 2
fpu             : yes
fpu_exception   : yes
cpuid level     : 11
wp              : yes
bogomips        : 7181.66
clflush size    : 64
power management:
processor       : 6
cpu family      : 6
model           : 44
stepping        : 2
cpu MHz         : 1596.000
physical id     : 0
siblings        : 4
core id         : 9
cpu cores       : 4
apicid          : 18
initial apicid  : 18
fpu             : yes
fpu_exception   : yes
cpuid level     : 11
wp              : yes
bogomips        : 7181.66
clflush size    : 64
power management:
processor       : 7
cpu family      : 6
model           : 44
stepping        : 2
cpu MHz         : 1596.000
physical id     : 0
siblings        : 4
core id         : 10
cpu cores       : 4
apicid          : 20
initial apicid  : 20
fpu             : yes
fpu_exception   : yes
cpuid level     : 11
wp              : yes
bogomips        : 7181.66
clflush size    : 64
power management:
