Software Archive
Read-only legacy content
17060 Discussions
Missing Win32 controls - DateTimePicker, MonthCal
pcurtis
The DateTimePicker and MonthCal control types are still not supported by CVF6.6, at least via the easy way of setting up dialogs using the Resource Editor within DevStudio. I would very much appreciate any hints or code samples on how to implement these controls in a dialog, the "hard" way.
TIA, Paul Curtis
[email protected]
Jugoslav_Dujic
Valued Contributor II
Well, here's a snippet from an actual app containing a dialog with two DateTimePickers IDC_SPIN_YEAR and IDC_SPIN_HOUR (one for date, one for time). I apologize for overhead, since it evolved from an older code which utilized edits and spins instead. When MODE.NE.MODE_ONLINE, they behave as pickers; otherwise, they are disabled and act like a clock, driven by timer. Helper functions are not necessary (they used to be far bigger); they update global iHgod, iHdan etc. dTime is double in format YYYYMMDD.hhmmss used for interchange between helpers.
LOGICAL(4) FUNCTION TimeDlgProc(hWnd,Msg,wParam,lParam)
!DEC$ATTRIBUTES STDCALL:: TimeDlgProc
USE Whatever_needed
IMPLICIT NONE
INCLUDE "Resource.fd"
INTEGER::                     hWnd,Msg,wParam,lParam
TYPE(T_SYSTEMTIME)::          TST
TYPE(T_NMHDR)::               Header; POINTER(lpHeader,Header)
CHARACTER(40)::               sTimeFormat
CHARACTER(20)::               sDateFormat
REAL(8)::                     dTime,dCurrTime
SELECT CASE(Msg)
CASE (WM_INITDIALOG)
      iSt=GetLocaleInfo(LOCALE_USER_DEFAULT, LOCALE_STIMEFORMAT, sTimeFormat, LEN(sTimeFormat))
      iSt=SendMessage(GetDlgItem(hWnd,IDC_SPIN_HOUR),DTM_SETFORMAT,0,LOC(sTimeFormat))
      iSt=GetLocaleInfo(LOCALE_USER_DEFAULT, LOCALE_SSHORTDATE, sDateFormat, LEN(sDateFormat))
      iSt=SendMessage(GetDlgItem(hWnd,IDC_SPIN_YEAR),DTM_SETFORMAT,0,LOC(sDateFormat))
      CALL GetLocalTime(TST)
      CALL InitTimeControls(hWnd,TST%wMinute,TST%wHour,TST%wDay,TST%wMonth,TST%wYear)
      iSt=GetDlgTime(hWnd,dTime)
      CALL UpdateTime(dTime)
      TimeDlgProc=.FALSE.
CASE (WM_NOTIFY)
      lpHeader=lParam
      IF (wParam.EQ.IDC_SPIN_HOUR .OR. wParam.EQ.IDC_SPIN_YEAR) THEN
            IF (Header%Code.EQ.DTN_DATETIMECHANGE) THEN
            END IF
      ELSE
            TimeDlgProc=.FALSE.
      END IF
CASE (WM_TIMER)
      IF (MODE.EQ.MODE_ONLINE) THEN
            iSt=SendMessage(GetDlgItem(hWnd, IDC_SPIN_HOUR), DTM_SETSYSTEMTIME, GDT_VALID, LOC(TST))
            iSt=SendMessage(GetDlgItem(hWnd, IDC_SPIN_YEAR), DTM_SETSYSTEMTIME, GDT_VALID, LOC(TST))
      TimeDlgProc=.FALSE.
CASE DEFAULT
      TimeDlgProc=.FALSE.
END SELECT
END FUNCTION TimeDlgProc
continued...
Jugoslav_Dujic
...continued:
SUBROUTINE InitTimeControls(hWnd,iMinute,iHour,iDay,iMonth,iYear)
!Sets values of DateTimePickers
USE DFWIN
USE COMCTL
USE DTPICKER
IMPLICIT NONE
INTEGER,INTENT(IN)::    hWnd
INTEGER(2),INTENT(IN):: iMinute,iHour,iDay,iMonth,iYear
INTEGER::               iSt
TST=T_SYSTEMTIME(INT2(iYear),INT2(iMonth),5,INT2(iDay),INT2(iHour),INT2(iMinute),0_2,0_2)
iSt=SendMessage(GetDlgItem(hWnd,IDC_SPIN_HOUR), DTM_SETSYSTEMTIME, GDT_VALID, LOC(TST))
iSt=SendMessage(GetDlgItem(hWnd,IDC_SPIN_YEAR), DTM_SETSYSTEMTIME, GDT_VALID, LOC(TST))
END SUBROUTINE InitTimeControls
LOGICAL(4) FUNCTION GetDlgTime(hWnd,dTime)
!Retrieves values of DateTimePickers into dTime
USE DFWIN
USE COMCTL
USE DTPICKER
USE STRINGS
IMPLICIT NONE
REAL(8),INTENT(OUT)::   dTime
TYPE(T_SYSTEMTIME)::    tTime, tDate
INTEGER::               iSt
GetDlgTime=.TRUE.
iSt=SendMessage(GetDlgItem(hWnd,IDC_SPIN_HOUR), DTM_GETSYSTEMTIME, 0, LOC(tTime))
iSt=SendMessage(GetDlgItem(hWnd,IDC_SPIN_YEAR), DTM_GETSYSTEMTIME, 0, LOC(tDate))
dTime=10000._8*tDate%wYear + 100._8*tDate%wMonth + tDate%wDay + &
      tTime%wHour/100._8 + tTime%wMinute/10000._8
END FUNCTION GetDlgTime
SUBROUTINE UpdateTime(dTime)
!Copies contents of dTime into global iH* variables
USE HISTORY
USE me_com1
IMPLICIT NONE
REAL(8),INTENT(IN)::    dTime
REAL(8)::               dTime2
iHGod=INT(dTime)/10000
iHMes=(INT(dTime)-10000*iHGod)/100
iHDan=INT(dTime)-10000*iHGod-100*iHMes
dTime2=dTime-INT(dTime)
iHSat=INT(100*dTime2)
iHMin=NINT(10000*dTime2)-100*iHsat
iVrem=NINT(10000*dTime2)
iDatMer=INT(dTime)
END SUBROUTINE UpdateTime
Dialog, if modal, is invoked using
hTimeDlg=DialogBox(hInst,MAKEINTRESOURCE(IDD_DIALOG_TIME),hFrame,    &
      LOC(TimeDlgProc))
Also, you have to initialize datetime classes somewhere at application start:
TYPE (T_INITCOMMONCONTROLSEX)::  iCCE
iCCE%dwSize=8
iCCE%dwICC=ICC_DATE_CLASSES
iSt=InitCommonControlsEx(iCCE)
HTH
Jugoslav
