Software Archive
Read-only legacy content
17060 Discussions
Missing start-stop-daemon
Mario_B_
I've been struggling since the beggining with this, every init scrip containing 'start-stop-daemon' fails to start. First it happened with 'ntp' now with 'busybox-syslog'
Starting syslogd/klogd: /etc/rc3.d/S20syslog: line 57: start-stop-daemon: command not found.
Here a sample of syslog.busybox
case "$1" in
  start)
        echo -n "Starting syslogd/klogd: "
        start-stop-daemon --start -b -n syslogd -a /sbin/syslogd -n $SYSLOG_ARGS                      start-stop-daemon --start -b -n klogd -a /sbin/klogd -n
        echo "done"
  stop)
        echo -n "Stopping syslogd/klogd: "
        start-stop-daemon -K -n syslogd
        start-stop-daemon -K -n klogd
        echo "done"
  restart)
        $0 stop
        $0 start
start-stop-daemon is not under /sbin or any other place. I run linux image 1.0.4 on Galileo Gen 2.
How should I do to install 'start-stop-daemon' ? Thanks in advance!
Matthias_H_Intel
I'd suggest comparing other init scripts. Or you move to the Intel IoT devkit SD card image which is on systemd and uses systemd services rather than init scripts.
Pls note that this forum has been deprecated in favor of https://communities.intel.com/community/makers. In order to get full attention pls ask on the latter
Matthias_H_Intel
just found your other post https://communities.intel.com/thread/67180 on the makers forum.
So let's continue there
