Software Archive
Read-only legacy content
17060 Discussions
Native LCD Res doesnt work in XP
thetman2
I have VAIO TZ170 with an 11.1" LCD. It has a native res of 1366x768. When I wiped vista and install xp with the latest drivers the max resolution I can set is 1024x768.
Here is my monInfo results:
Monitor
Windows description......... Digital Flat Panel (1024x768)
Manufacturer................ MS_
Plug and Play ID............ MS_0003
Serial number............... 13 (12000013)
EDID data source............ Registry (stored)
Manufacture date............ 2002
EDID revision............... 1.3
Display type and signal..... Digital
Sync input support.......... n/a
Screen size................. 2550 x 2550 mm (~155")
Power management............ Active off/sleep
Color characteristics
Display gamma............... 3.55
Red chromaticity............ Rx 0.625 - Ry 0.340
Green chromaticity.......... Gx 0.285 - Gy 0.605
Blue chromaticity........... Bx 0.148 - By 0.063
White point (default)....... Wx 0.281 - Wy 0.309
Timing characteristics
VESA GTF support............ Supported
Horizontal scan range....... 0-160kHz
Vertical scan range......... 0-60Hz
Video bandwidth............. 80MHz
Extension blocks............ n/a
Timing recommendation #1.... 1366x768 at 60Hz
Modeline................ "1366x768" 76.100 1366 1430 1494 1643 768 769 770 772 -hsync -vsync
Timing recommendation #2.... 1366x768 at 40Hz
Modeline................ "1366x768" 76.090 1366 1622 2134 2464 768 785 786 772 -hsync -vsync
Standard timings supported
1366 x 768 at 40Hz - MS_
1366 x 768 at 60Hz - MS_
Raw EDID base
00: 00 FF FF FF FF FF FF 00 36 7F 03 00 0D 00 00 00
10: 00 0C 01 03 80 FF FF FF 2F 00 00 A0 57 49 9B 26
20: 10 48 4F 00 00 00 01 01 01 01 01 01 01 01 01 01
30: 01 01 01 01 01 01 BA 1D 56 15 51 00 04 30 40 40
40: 11 00 00 00 00 00 00 18 B9 1D 56 4A 54 00 04 30
50: 00 00 11 60 00 00 00 00 00 18 00 00 00 FD 00 00
60: 3C 00 A0 08 00 00 00 00 00 00 00 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F5
Display adapter
Adapter description......... Mobile Intel 945 Express Chipset Family
Adapter device ID........... 0x27A28086
Display settings............ 1024x768, 32bpp
why cant I set a higher resolution. even the intel gma software says the correct display mode but wont let me set it.
I have read other posts where DTDs needed to be changed. I can do that just dont know what settings to use.
Thanks in advance for helping .
Aaron_B_Intel
Try
BA 1D 56 15 51 00 04 30 40 4011 00 00 00 00 00 00 18
Also possible: VAIO BIOS may be prohibiting 1366x768. Try 1364x768:
BA 1D 54 17 51 00 04 30 40 4011 00 00 00 00 00 00 18
The third possibility is the persistence bug which has been seen on many systems since driver release 14.33.
thetman2
I tried both neither worked. Thanks for the help though, I just went back to vista works fine there.
