Software Archive
Read-only legacy content
New tool available in beta: Vectorization Advisor
BelindaLiviero
Software must be both threaded and vectorized to get the full performance benefit from today’s and tomorrow’s hardware.  Vectorization Advisor is a vectorization analysis tool that lets you identify loops that will benefit most from vectorization, identify what is blocking effective vectorization, explore the benefit of alternative data reorganizations, and increase the confidence that vectorization is safe.
Vectorization Advisor is now available for beta test as a part of Intel® Advisor XE 2016.
Watch the vectorization advisor webinar, learn more about the beta program and sign-up to try Vectorization Advisor.
aketh_t_
Hi Belinda,
We are part of an IPCC program at IISc India.
I hope I am commenting/posting/querying at the right place.
1)Is this vectorization tool work for parallel applications?
2)Does it point out loops/areas that are thread level parallelizable but currently are not?
Frances_R_Intel
1) Vectorization Advisor will give you information regardless of whether or not you have used some form of multithreading on the code - OpenMP, MPI, etc. The advice it gives you might be different for code which is also multithreaded if what you have done changes the loop structure but in most cases, the advice should be the same.
2) It only provides advice on vectorization. There is a second tool, Threading Advisor, for multithreading. Together they are called Intel® Advisor XE.
You can find out more about Intel® Parallel Studio XE 2016 Beta, the first release containing Vectorization Advisor, here: https://software.intel.com/en-us/articles/intel-parallel-studio-xe-2016-beta.
You can find the Getting Started Guides for these tools here: https://software.intel.com/en-us/advisor_getting_started_intro.
As to whether this was the right place for you to post your question, for something very short like this that can be answered easily, it is ok but in general, it is better to start a new thread specifically for you question by clicking on the New Topic button for the forum you want to post to. This makes it easier to track which questions have been addressed.
Brat__Steve
The perception where it will be going to provide the most of the part for such a way that is going to have the integrated for the convince way where the Epson error code 0x69 user will integrate the core part
Jacob__mark
The perception where it will be going to provide the most of the part for such a way that is going to have the integrated for the convince way where you can follow the instructions to fix Epson error code 0x69
GameMaker__TheBest
Thanks mate, Vectorization Advisor is great tool for analyzing
