Software Archive
Read-only legacy content
17060 Discussions
Offload from dynamic link library
Fedor_Z_
I am new to programming for the Xeon Phi, and I am having trouble getting explicit offload to work when the offload is done in a dynamic-link library. The code fails at run time at the offload location, with a messages:
"offload error: Cannot find host executable
offload error: cannot start process on the device 0 (error code 6)"
If I am setting environment variable OFFLOAD_INIT=on_start I get the next message:
"[Offload] [MIC 0] [File]                    c:\temp\init_xeon.cpp
[Offload] [MIC 0] [Line]                    28
[Offload] [MIC 0] [Tag]                     Tag 0
offload error: cannot create pipeline on the device 0 (error code 14)"
I am using C++ on  Windows Server 2012R2, using Parallel Studio XE 2015 Update 6 Cluster Edition, MPSS version 3.6.1.
A simple example of what I'm trying to do is below :
A basic main program which loads the dynamic library and calls the function in it :
int _tmain(int argc, _TCHAR* argv[])
	HINSTANCE hInstLib = LoadLibraryA("TestXeonDll.dll");
	_StartDllXeonInit	StartDllXeonInit	= (_StartDllXeonInit)	GetProcAddress(hInstLib, "StartDllXeonInit");
 	StartDllXeonInit();
 	FreeLibrary(hInstLib);
	return 0;
And the contents of dynamic library:
void StartDllXeonInit()
	init_xeon();
void init_xeon()
	uint32_t  a = 0;
#pragma offload target(mic) inout(a)
		a += 1;
If I do the offload in the main program, it works fine. Any clues as to what I'm doing wrong ?
Fedor.
Linm_F_
 Hi,Fedor Z !
      Nowadays,  I have the same problem with you, have you solved this problem?
      I'm  nearly crazy about this problem, so I very looking forward your help.
      Thanks !
