Software Archive
Read-only legacy content
17060 Discussions
OpenCL rpm issues
JJK
New Contributor III
Hi all,
while investigating https://software.intel.com/en-us/forums/topic/534808 I decided to install the OpenCL drivers for the Xeon Phi; I ran into two issues while installing the package opencl_runtime_14.2_x64_4.5.0.8.tgz:
  1. RPM verification fails:
    Unsatisfied dependencies for opencl-1.2-base-1:4.5.0.8-1.x86_64:
    	opencl-1.2-intel-common >= 1:4.5.0.8 is needed by opencl-1.2-base-1:4.5.0.8-1.x86_64
    I could not find the RPM opencl-1.2-intel-common anywhere in the instalaltion package
  2. the RPM opencl-1.2-intel-cpu-4.5.0.8-1.x86_64 has a 'verify' scriplet that fails:
    set -e;
    err=0;
    res="";
    bulk="`dirname $RPM_INSTALL_PREFIX`/opencl-1.2-4.5.0.8/lib64/libintelocl.so";
    size=${#bulk};
    stat=( $(/bin/stat --format="%s" "`dirname $RPM_INSTALL_PREFIX`/opencl-1.2-4.5.0.8/etc/intel64.icd") );
    The 'stat' command is located in /usr/bin/stat on CentOS 6 and Scientific Linux.
Loc_N_Intel
The Intel OpenCL run-time package opencl_runtime_14.2_x64_4.5.0.8.tgz was validated with MPSS 3.3 according to https://software.intel.com/en-us/articles/opencl-runtime-release-notes . So please use the MPSS 3.3 (located at https://software.intel.com/en-us/articles/intel-manycore-platform-software-stack-mpss-archive ) if you want to install the above Intel OpenCL run-time package. Thank you.
JJK
New Contributor III
I will try downgrading to mpss 3.3 (with a known Bash vulnerability in it! ) but I'm 99.9% confident that it won't matter. Both issues that I reported are actually unrelated to the Xeon Phi.
shuanshuan_b_
hello,I got the same question as yours when I try to install opencl_runtime. But when I use the install.sh to install, it remind me that the runntime does not support my Operation System, please check.
TaylorIoTKidd
Shuanshuan,
Please elaborate. Are you having the same non Xeon Phi issues that Jan Just had?
Taylor
sapet__frederic
Hello
I have downloaded the archive :
intel_sdk_for_opencl_2016_6.3.0.1904_x64.tgz
Where can I found this missing RPM ?
rpm -ivh opencl-1.2-base-6.3.0.1904-1.x86_64.rpm
warning: opencl-1.2-base-6.3.0.1904-1.x86_64.rpm: Header V3 RSA/SHA1 Signature, key ID 7a5a985f: NOKEY
error: Failed dependencies:
        opencl-1.2-intel-common >= 1:6.3.0.1904 is needed by opencl-1.2-base-1:6.3.0.1904-1.x86_64
Thank you.
