Software Archive
Read-only legacy content
17060 Discussions
OpenHPC KNL cluster runs very slow
Per_J_
I have tried to install openHPC with Warewulf stateless provision and SLURM and it runs really slow :-(
HPL benchmark on a normally installed 7210 is around 1700 GFlops but on a Warewulf installed node it is only 140 GFlops more than 10x slower.
I only got 1G ethernet on the nodes and 10G on the master.
How should I install OpenHPC on a KNL cluster, or should I install something else?
Per
Per_J_
It seems to be related to the motherboard vendor.
I am only using the 16GB MCDRAM for computation and I tested if I could add RAM in one DIMM for system programs and have the MCDRAM as hotplug.
This works on the Supermicro K1SPE motherboard but not on the ASRock 2U4N-F/X200.
On the ASRock there is no option for making MCDRAM hotpluggable and if only one DIMM is occupied the HPL benchmark is 1/6th and with 2 DIMM 1/3rd
Valjean__Jean
Hi Per,
"Recently" I bought in ebay an Asrock motherboard X200D6HM with 7250 (and a spare 7210)
I've spent few days (maybe 2 week) trying different os and memory configs (the versions written in xpss manual, newer versions ...redhat, centos), finally I gave-up, I thought that I must be a "knight" to work with knl  ...
To be honest also knc gave me headaches, but finally knc works.
Because I saw you already made comparisons with supermicro My question is: - is knl with Asrock motherboard working well for you, now? Did you manage to make it works well ? Maybe you have some trick where I should pay attention more.
Mine is very slow, I didn't benchmarked it but in that time I've tried a small omp code which took longer with 40% than an old 6 core processor avx2. The code has around 60 threads, so enough to be faster in knl.
thank you
bios is s4c with cache
[root@s21 a]# numactl -H
available: 4 nodes (0-3)
node 0 cpus: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221
node 0 size: 32646 MB
node 0 free: 30118 MB
node 1 cpus: 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
node 1 size: 32768 MB
node 1 free: 31222 MB
node 2 cpus: 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255
node 2 size: 32768 MB
node 2 free: 31741 MB
node 3 cpus: 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271
node 3 size: 32768 MB
node 3 free: 31365 MB
node distances:
node   0   1   2   3
  0:  10  21  21  21
  1:  21  10  21  21
  2:  21  21  10  21
  3:  21  21  21  10
