Software Archive
Read-only legacy content
17060 Discussions
P12 up to intel xdk but i don't work
Ulises_G_
My name is Ulises and i have this problem.
The archive p12 is in intel xdk but the program dont give the option for to sign.
atached screen picture show this problem.
Thanks for your reply.
Ulises
PaulF_IntelCorp
Ulises -- the image you provided is too small, I cannot see the necessary details. Can you provide an image with higher resolution.
Did you "convert" the existing P12 file? See this video > https://software.intel.com/en-us/videos/upgrading-an-existing-intel-xdk-project-to-version-3088 <
Ulises_G_
Ulises_G_
Hello Paul,
See at the picture i have the certificate but the intel xdk say..."no certificate found"
Thanks and best regards
Ulises
PaulF_IntelCorp
I wonder if the space characters are causing a problem? We have had some issues in the past where special characters in the name of a certificate would cause issues.
I suggest you download the certificate, rename it to using only letters, numbers and dash characters, and then import it into the certificate store under the new name.
