Software Archive
Read-only legacy content
17060 Discussions
PXCFaceModule, setting the stream resolution
Matthew_H_2
When I run the sample code DF_FaceTracking with my F200 camera, and then query the available streams from another RealSense application, I get only this:
Module[0]: 0000005ACCB8EEB0
Device[0]: 0000005ACCB8F120
color[0]: 640x360@30-30
depth[0]: 640x480@30-30
So it seems the face tracking module is setting the camera stream to the above parameters in "Static Application" mode. In the docs "Working with Multiple Modalities" the F200 Face Tracking (3D) modality is listed as working under almost all color and depth resolution combinations available.
I can't find anything in the docs about requesting the PXCFaceModule use a higher resolution stream. Is this possible? I think there is something like this described in the "Module Configuration" section of the docs, but it seems vague. Is there example code available?
Matthew_H_2
The example code in "Connecting I/O via CaptureManager" does not seem to work.
sts = videoModule->QueryCaptureProfile(0, &videoData); // assume a single camera
captureManager->RequestStreams(1, &videoData);
sts = captureManager->LocateStreams();  // always returns PXC_STATUS_ITEM_UNAVAILABLE
Though I'm not sure I know what this description of index means in QueryCaptureProfile.
index
The zero-based index to enumerate all available configuration parameters.
Matthew_H_2
Bump -- Does anyone have some advice on this?
