Software Archive
Read-only legacy content
17060 Discussions
Parallel Inspector "memory errors" ends prematurely with no data collected
jurektr
When I run Parallel Inspector with "memory errors" selected the environment seems to switch to the execution mode but my application does not seem to even start and after a couple of seconds the execution mode ends and inspector shows no data collected. At the same time "threading errors" work fine and Amplifier works fine. What am I doing wrong?
Thanks - Jurek
Vladimir_T_Intel
Quoting - jurektr
Thanks - Jurek
HiJurek,
Could you attach the results directory? (pls, compress it)
What type of application you were trying to analyse?
Which OS you were using?
