Software Archive
Read-only legacy content
17060 Discussions
Pause and resume auto white balance / exposure, while.preserving value.
Boris_K_
If after running with AutoWhiteBalance as true for a while, then setting:
device->SetColorAutoWhiteBalance(false);
I end up with a sharp change to what I assume the defaults. I try to work around this by doing:
auto wb = device->QueryColorWhiteBalance();
device->SetColorWhiteBalance(wb);
But it has the exact same result as above. Does querying it return only the default values?
All I want is to do is have white balance auto adjust, then turn auto adjusting 'off' in order to record a set of frames with an unchanging exposure & balance values. Then set it back to auto adjust.
But I want to preserve the values that it automatically got to before I turn it off.
Boris
