Software Archive
Read-only legacy content
17061 Discussions
Phi 7240P on Centos: no MIC boards present
Jesus_C_
I installed MPSS 3.8.2 on a CentOS 7.3 system with kernel 3.10.0-514.16.1
I built the kernel module package for this kernel version. The mic module loads, but it reports "no MIC boards present"
I also tried booting with the default kernel, 3.10.0-514 (and the module from the MPSS rpm package). Again, the module loads but reports "no MIC boards present"
In lspci I can see the Xeon Phi card, and it seems to have memory assigned. On the other hand, miccheck fails on first test:
Executing default tests for host
  Test 0: Check number of devices the OS sees in the system ... fail
    no Intel(R) Xeon Phi(TM) coprocessors devices detected
Status: FAIL
I have attached a tgz with the output of lspci, dmesg, etc
Thanks in advance and kind regards,
JJK
New Contributor III
can you repost the tgz file? I can't find it; and do you really have a Phi 7240P as a PCI Express card? they're rare, I believe
Jesus_C_
I agree they are rare, but I believe it is a 7240P model.
Please find the .tgz file attached.
Thanks!
(Virus scan in progress ...)
JJK
New Contributor III
Jesus_C_
Greetings JJK,
Thanks a lot. I will try with MPSS 4.4.0. I was following directly the MPSS user guide and asumed that the latest version was 3.8.
Best wishes,
