Software Archive
Read-only legacy content
17060 Discussions
PointCloud (UnityToolkit Sample 6) and colored mesh
yosun
Innovator
Is there a way to obtain this data as a Texture2D and gameObject mesh?
Xusheng_L_Intel
I will check with my colleague and see if it is feasible and easy to implement. Thanks!
Amit_M_Intel
Hi Yosun,
In the sample, we are building a mesh from the point cloud, and setting the RGB image as it's texture.
You can take a look at the scripts "PointCloudViewer.cs" and "DrawImages.cs"
Amit
yosun
Innovator
Hi Amit, the provided Texture does not seem to have the right texture/uv mapping - as seen when you turn on the "use UV map" in both "PointCloudMesh - no color mapping" and "PointCloudMesh - with Color mapping"
The current video-output to UVmap seems to both flip and tile the video (randomly? - the borders do not seem consistent)
